Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Whiplash
MA Whiplash Miniature Aircraft Whiplash Helicopter Support Forum
Old 05-16-2012, 01:18 AM   #1 (permalink)
Default Swash level for Whiplash
As you can see from the picture below, my current swash leveler that I use for the T550 and T600Pro is too wide for the Whiplash swash plate. Can you guys recommend a swash leveler that will work with the Whiplash swash plate? Please, include a link if possible. Thanks.
Name:	Swash leveler-small.JPG
14S Specter 700 V2 NME/Tron 7/Kraken; 8S Tron Dnamic; 7S Kraken 580; 6S Buddy 380 KSE
VBCE/Neo/EVO, Jeti/Spirit, YGE "T" ESCs; LiFePO4 field charging batteries
Sims on Mac: Heli-X, neXt, AccuRC, Phoenix, AeroFly RC7 Ultimate
Amain Team Pilot
Old 05-16-2012, 03:52 AM   #2 (permalink)
Try one of these..
http://www.rcheliworld.com.au/index....product_id=865
scootr is offline        Reply With Quote Quick reply to this message
Old 05-16-2012, 02:54 PM   #3 (permalink)
I got mine local. I just called the shop and this is the one they sold me. Looks right.
http://helidirect.com/sa00137a-swash...50-p-26145.hdx
The fusion also has a narrow swash and 10mm main. This lands on the swash above the link balls. An does not touch the links. It's perfect.
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 05-16-2012, 02:58 PM   #4 (permalink)
Thank you so much. I was about to place an order with helidirect. I just added this tool to the cart. Thanks
Amain Team Pilot
Old 05-17-2012, 07:16 AM   #5 (permalink)
Anyone find one that you don't have to take the head off?
zaboaa is offline        Reply With Quote Quick reply to this message
Old 05-17-2012, 07:17 AM   #6 (permalink)
The compass 7hv under swash leveler would work. It slides between the frame and the swash.
Old 05-19-2012, 01:54 AM   #7 (permalink)
A very simple way to modify that is to take a strip of CF the width of the lower face that sits on the swash and cut it the length of that lower face plus ever how much you need it to poke out so that it will reach the swash arm. Sand the edges smooth and put a drop of CA on each CF piece and glue it to the lower face so that it protrudes out towards the center shaft and will engage the swash arm.
This way you don't have to purchase a whole new swash tool.
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Hobbies Team Rep
rcflyerheli is offline        Reply With Quote Quick reply to this message
Old 05-21-2012, 01:11 AM   #8 (permalink)
K&S
http://www.amainhobbies.com/product_...-Leveling-Tool
Robert Montee | Team Futaba USA | Team Kontronik USA | TellARotor RC Podcast | Citizen 13
Full Montee is offline        Reply With Quote Quick reply to this message
Old 05-22-2012, 10:12 AM   #9 (permalink)
I tested this swash leveler, and it works perfectly. Thanks.
Amain Team Pilot
Old 05-22-2012, 11:55 AM   #10 (permalink)
Great!! Glad to hear it!
Old 06-01-2012, 06:54 PM   #11 (permalink)
+1 on the link Scootr posted above. It is made by MA specifically for their swash plates. Ive been using mine for years and it works great. Being that it has a round plate, it helps to level the swash at all four points instead of three (like most levelers do).
Rob V.
robv is offline        Reply With Quote Quick reply to this message
Old 08-21-2012, 12:23 PM   #12 (permalink)
I just wanted to follow up. After trying the Outrage leveler that I originally thought worked perfectly, it turns out that the Outrage leveler, at least the one I have, is not 100% level. After "leveling" the swash with the Outrage leveler, If I spin the Outrage leveler 120 degrees, so that the Outrage leveler tripod arms sit on different swash protrusions, small gaps become evident. I ended up marking one of the Outrage leveler arms to correspond with the elevator servo to at least keep the level measurement error consistent at low, mid, and high stick.
Although I could not notice any decrement in flight performance, just knowing that the swash was not really leveled due to the limitations of the Outrage leveler itself was eating my up inside.
I decided to order the MA 3000-10 swash leveler as others have recommended. Since it is round, it should level the swash at 4 points, rather than that just 3 points as the regular tripod swash levelers. Made by MA, specifically for the MA helicopters, it should be perfect. Unfortunately, just like the Outrage, this MA leveler allows for the appearance of tiny gaps, if I spin this tool around. Again, no decrement in flight performance, but still bothered me.
I recently ordered the TrueBlood swash leveler https://www.readyheli.com/LEVELER4-L...g_p_34924.html. It is similar to the TrueBlood Leveler2, in that it fits 10mm shafts. However, unlike the Leveler2 which fits the T-Rex 550E and 600Pro longer swash arms, this Leveler4 has shorter arms that the fit the Whiplash swashplate. This TrueBlood leveler is more expensive than the other 2 levelers, but it is more precise than the other 2 levelers. Once I level the swashplate with this TrueBlood, I can spin the TrueBlood around the shaft, and cannot notice any gaps. Again, I cannot notice any improvement in flight performance compared to setting up with the other levelers, but this leveler is more precise.
These are the 3 levelers.
Below is the TrueBlood on the swashplate
Name:	Whip Swash leveler 1-small.JPG
ID:	342436   Click image for larger version
Name:	Whip Swash leveler 2-small.JPG
ID:	342437   Click image for larger version
Name:	Whip Swash leveler 3-small.JPG
Amain Team Pilot
Old 08-21-2012, 01:52 PM   #13 (permalink)
Great info John! Thanks for passing along!
X-Cell Whiplash, Konk 700-45, Skook 540, Mav 710's, YGE 160HV...
itbvolks is offline        Reply With Quote Quick reply to this message
Old 08-21-2012, 06:20 PM   #14 (permalink)
I use the same MA leveler on my Whiplash and have never had a problem. Fits perfectly and nice and straight for me.
- Josh
Team - "Self Interests" -
Flying what I want to, simply because I enjoy it!
Seasick78 is offline        Reply With Quote Quick reply to this message
Old 08-22-2012, 08:09 AM   #15 (permalink)
The MA 3000-10 leveler seems more precise than the Outrage leveler. Again, their level of imprecision is minuscule, but it is there. After I level the swashplate with the MA 3000-10 leveler, if I spin the MA 3000-10 leveler by 1/8 turns, I can notice gaps, however minuscule, that where not there before. I don't see any such gaps when I level with the Trueblood, and later spin the Trueblood by 120 degree turns.
Amain Team Pilot
