Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Old 04-02-2014, 04:56 PM   #1 (permalink)
Default S Ducts...
Anybody using them?
Diabolo S #41
TDR 2
The others come and go..
craigdieselmac is offline        Reply With Quote Quick reply to this message
Old 04-03-2014, 02:34 AM   #2 (permalink)
Thatīs the reason we add them. But because there are different controllers and motors available we cannot factory mount them.
Also the sound like an arrow when the S is passing is probably coming from the ducts
Gerd is offline        Reply With Quote Quick reply to this message
Old 04-03-2014, 03:20 AM   #3 (permalink)
Sound like an Arrow!! Well now im going to install mine....
William Blake Team Kontronik
TDR1, Banshee 850 # 22
Diabolo 700
wblombard is offline        Reply With Quote Quick reply to this message
Old 04-03-2014, 06:01 AM   #4 (permalink)
Where should I mount them for the Kosmik?
Diabolo S #41
TDR 2
Old 04-03-2014, 09:54 AM   #5 (permalink)
X2!
_____________________
JRAY is offline        Reply With Quote Quick reply to this message
Old 04-03-2014, 12:50 PM   #6 (permalink)
Here a small drawing from #13 (with Kosmik 200 and Xera 4535):
Old 04-04-2014, 03:29 AM   #7 (permalink)
Thanks Gerd!
Diabolo S #41
TDR 2
Old 04-26-2014, 10:09 PM   #8 (permalink)
Just fyi if you're running a Kosmik Cool. I installed using the diagram measurements, and I had to trim the ducts, because they were hitting the fan keeping the nose from seating, and of course, there's no changing it once the holes were cut. I would prefer them to be another 10mm forward, and that would have put them directing air right into the Cool's heatsink. I think it will be fine as it's though, because air will be flowing right over the fan.
Old 04-26-2014, 11:29 PM   #9 (permalink)
Jason,
Could you post a picture please?
I'm dreading cutting this canopy, but I have no choice
Diabolo 700
Old 04-26-2014, 11:31 PM   #10 (permalink)
Just to make sure I understand correctly.....does this get installed 83mm measured from the front end or back end of the canopy
Diabolo 700
Old 04-27-2014, 12:50 AM   #11 (permalink)
CHC Benefactor
Hi William, that's 183mm (European 1) and definitely from the back of the top of the canopy, ie. the curve just in front of the swash. Notice the leading portion of the ducts are closer together, which should be at the front. Cheers.
Old 04-27-2014, 12:57 AM   #12 (permalink)
Thank Geoff,
Rather ask than be like...oh shit!!
I will have to make sure the ducts dont interfere with push up against anything....I still need at least 2mm space...my canopy just does not want to go in any furture. Its actually all the kosmiks fault...I noticed Gerd had a mount on his pictures dropping the kosmik...therefore lowering the front end of the Kosmik...this will creat a lot more space...Need to see how I'm going to do that.
I feel sorry for the guys using the Cool Kosmik...damn I dont know how that is going to fit.
Diabolo 700
Old 04-27-2014, 12:59 AM   #13 (permalink)
HF MR Support
Default S Ducts...
That's why we are not using the ducts.
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 04-27-2014, 01:14 AM   #14 (permalink)
I have no choice!!! With the heat build up in the fuse there is a slight (minor) bump showing on the fuse where the elevator servo is mounted. I'm guessing the heat build up inside caused that area to soften showing where the fuse is under pressure. I'm not sure it is worth it to dismantle and dremmel that down.
Diabolo 700
Old 04-27-2014, 01:17 AM   #15 (permalink)
Thank Geoff,
Rather ask than be like...oh shit!! .
I have a cool Kosmik, not by choice, only one in the LHS. As I said by PM, took some serious Dremelling to get it to fit!
I have no ducts, just a 10mm hole and a Mauro HS motor mount. I feel heats sinking is the key for these short flights, not sure active cooling of any benefit!
John
Old 04-27-2014, 01:32 AM   #16 (permalink)
John, can you post some pictures please? I love to see what you have done with regards to the kosmik and the hole
Diabolo 700
Old 04-27-2014, 05:30 AM   #17 (permalink)
I have a kool kosmik and the ducts already installed guess I will have to figure this one out
Diabolo S #6
Diabolo
TDR
N7
crash at 42 is offline        Reply With Quote Quick reply to this message
Old 04-27-2014, 05:34 AM   #18 (permalink)
HF MR Support
Default S Ducts...
Can you post a couple of pics of the front end with the ducts.
Lynh
Old 04-27-2014, 05:46 AM   #19 (permalink)
Quick conversion the top of the ducts are mounted 177.8mm from the top, slightly less than what gerd posted earlier hopefully this will make a difference
ID:	505082   Click image for larger version
ID:	505083   Click image for larger version
Diabolo S #6
Diabolo
TDR
N7
Old 04-27-2014, 06:35 AM   #20 (permalink)
Default S Ducts...
Not rocket science William, I'm afraid! Just an 8mm hole and some unsightly modding of cooling fins on the Kosmik
John
