Go Back   HeliFreak > Multi Rotor Support > Flight Controllers (NAZA, Wookong, A2, etc...) > DJI Multirotor Forum(A2/WKM)
DJI Multirotor Forum(A2/WKM) DJI Multirotor Forum(A2/WKM)
Old 04-13-2013, 06:47 AM   #1
eddix99
Default NAZA M Cant GPS lock
Hi there,
Has anyone else had difficulty locking on to satellites. My LED keeps blinking 3 red then 1 green when in gps atti mode?
I cant seem to find a lock. Could the antenna be damaged?
Many thanks in advance
Walkera Mini CP & Master CP
Trex 500 Pro DFC with Helicommand HC3-SX (Finished at last!)
Gaui 330x-s, Naza M GPS, Gopro Black, Fatsharks
eddix99 is offline        Reply With Quote
Old 04-17-2013, 02:01 PM   #2
jim treg
3 reds and 1 green is locked into 5 satellites, and that is fine.
DJI 550 extended / Y6 custom build / X8 custom build / Quad custom build, Trex 500-MD500E / Trex 500-EC135. All using NAZA controllers, Walkera 450/Bell 222, Walkera 400 5 blade.
jim treg is offline        Reply With Quote
Old 04-17-2013, 04:54 PM   #3
Rumblecloud
Sometimes it take awhile to find a lock. I found this out by surprise as I was having the what I thought was the same problem. I had given up and was futzing with the TX and to my surprise it turned to two reds and one green then a few seconds later one to one and then finally all green.
Make sure you're outside in the open, fire it up and get a cup of coffee.
r
Rumblecloud is offline        Reply With Quote
Old 05-06-2013, 11:18 PM   #4
Empire Support 2
Originally Posted by eddix99 View Post
Hi there,
Sometimes, if you have not flown for a while, the small battery in the GPS gets low and looses the location stored in the unit. When you plug your flight battery in, the battery gets charged. The first time I fired up my WKM it took almost an hour to get a full GPS lock. I have never seen a Naza take that long. Good advice from Rumblecloud, plug it in and find a seat and wait.
Empire Support 2 is offline        Reply With Quote
Old 05-08-2013, 01:04 PM   #5
Sailingeric
The last few days mine has locked quicker than the week or so before.. I suspect some the solar flares have added to some of the slow locking issues you might be having.
I don't always fly but when I do I fly FPV. Stay airborne my friend.
TBS Discovery with Naza w/GPS; DX9 radio
Sailingeric is offline        Reply With Quote
