Old 08-07-2013, 02:28 PM   #1 (permalink)
Default Using a charger as a laptop power supply
So I find myself on a farm in Denmark (my home is outside of Boston), and first of all, I'm really glad I brought a heli ... I've never flown truly big sky before and it's awesome.
But my laptop power supply died, and being on a farm in rural Denmark, it isn't easy finding a replacement. It requires 20V @ 4.5 amps. It occurs to me that I might be able to use 2 3S lipos in series, or better yet, maybe there is some way to get my charger (a Hyperion Duo 610) to output 20V @ 4.5 amps and act as its power supply. If I set it to charge 14S NiMH, that would be 21V I think, but I don't think it's a steady 4.5amps ... I don't know enough about what the algorithm is to charge a NiMH (of NiCD) battery. Is this just a crazy thought, or is it possible it would work?
Compass 7HV (SK720BE w/GPS1)
Oxy4 (Spirit 2) / Oxy3 (SK720 Blue)
JR 11X
Shabill is offline        Reply With Quote Quick reply to this message
Old 08-07-2013, 02:36 PM   #2 (permalink)
I vonder if the NiMh charger would work more steady?
If its fixed don't break it!
Bladecpnitro is offline        Reply With Quote Quick reply to this message
Old 08-07-2013, 03:16 PM   #3 (permalink)
Wouldn't it be more feasible to attempt to charge the laptop battery when needed through the charger, outside of the laptop?
Gaui X5 sweet! Warp 360 KST, B4503D Savox- all beastx, 250 SE flybarred-current shelf queen, 130X, Mcpx BL, Nano cpx, Mini Dragonfly, DX8 AMA #982022 If you get to thinking you're a person of influence, try ordering somebody else's dog around.
shreddedpaper is offline        Reply With Quote Quick reply to this message
Old 08-07-2013, 03:27 PM   #4 (permalink)
I don't know the specifics of your charger but most are constant current.
Meaning it puts out 3A no matter what voltage is needed to have that current draw.
Your laptop power supply is constant voltage. Meaning always 20v no matter how much current draw.
Both different animals.
dcope17 is offline        Reply With Quote Quick reply to this message
Old 08-07-2013, 03:32 PM   #5 (permalink)
Probably easier to splice on a connector tip for the laptop than the laptop battery. I would set the chemistry and just plug it up at a setting no higher than spec. A little lower will be fine and just take longer to charge the battery but would probably still run the laptop. Consider your laptop running on battery after an hour or so...
Disclaimer: I haven't tried this and take no responsibility
California Cabernet & Cuban Cigars
Warp 360 | HC-3SX | JIVE 80+ | HK 2520-1360 | MKS DS92A+/95i | Radix | DX8 | PL6 | GP 6S 1500
Mr-Mike is offline        Reply With Quote Quick reply to this message
Old 08-07-2013, 03:36 PM   #6 (permalink)
This will be the better of the two solutions... Make sure you get the polarity correct.
As mention above your charger will not supply a constant voltage.
I guess there is not a "Staples" "Office Depot" "Radio Shack" store to buy a generic charger for the laptop?
dyuen888 is offline        Reply With Quote Quick reply to this message
Old 08-07-2013, 04:00 PM   #7 (permalink)
I would like for this to be vetted by the community before you try it...
Amps should be the capability to supply current. If your charger is supplying twice as many amps as required by the laptop, this should not yield a problem...
Gaui X7 Tribunus 200A, Xnova XTS 4525-530, Xpert R2/T, iKon2 BT
Gaui X5 HW 100A V3,Gaui 4020-910,KST, iKon[/FONT]
lucidchaos is offline        Reply With Quote Quick reply to this message
Old 08-07-2013, 04:20 PM   #8 (permalink)
Default Re: Using a charger as a laptop power supply
I feel like setting it for a 5s lipo and 4.5 amps would be close enough.
5% over voltage shouldn't hurt. Our chargers regulate voltage better than a laptop supply anyways.
It should make it drive to 21 volts, then sit at that constant voltage and supply whatever current is needed. If current drops to less than half an amp, the cycle will finish, but unless your laptop goes to sleep with a full battery, you should be fine.
mCPX V1 & V2 // 130 X // 450 Pro V2 -- ZYX-S // Fusion 50 -- BX
willr001 is offline        Reply With Quote Quick reply to this message
Old 08-07-2013, 04:25 PM   #9 (permalink)
Originally Posted by dcope17 View Post
I don't know the specifics of your charger but most are constant current meaning it puts out 3A no matter what voltage is needed
These statements are only correct for the first charge phase, which completes as soon as it hits the max voltage, at which point it switches to constant voltage to maintain that max.
If you set it to 5s and it makes it to 21 volts, you're home free, unless your laptop requires a signal line to identify "authorized" chargers. (Never buy a Sony laptop)
Old 08-07-2013, 06:54 PM   #10 (permalink)
I wouldn't do it. The charger is constantly trying to read battery voltage and change its output if needed, but your laptop is doing that too. I think there's a high chance you'll damage your laptop. If you were lucky enough for your charger's PSU to match the laptop's needs that would work.
Trex 450 Pro V2 - Stock with BeastX
mCP X, Nano QX
Fuzzy Toaster is offline        Reply With Quote Quick reply to this message
Old 08-07-2013, 07:45 PM   #11 (permalink)
Yes you can. Use the charger in Lead battery charging mode. Set it up with an appropriate number of cells to get close to 20V nominal. The Pb charging cycle is very amenable to being used as a power supply at constant voltage/Variable current.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote Quick reply to this message
Old 08-07-2013, 08:02 PM   #12 (permalink)
6 pins on the laptop battery; I have no idea which is for what ... no multimeter here on the farm ... and even if I had one, rigging up a connector would be tough based on the fact that they're all recessed and not standard to anything else I have. However, I stripped the laptop cord on the laptop side of the brick, and thankfully underneath the insulation is a black and a red cable going to the laptop. It should be as easy as attaching red to red and black to black, assuming (the big assumption) I can get 20V and at least 4.5 amps.
JR 11X
Old 08-07-2013, 08:09 PM   #13 (permalink)
That was my first thought. Unfortunately, the charger won't let me choose the right number of cells. When I tried it earlier tonight I had the option of 1,2,3,4,5,6 or 12 cells. I guess nobody makes a 10 cell Pb battery...
JR 11X
Old 08-07-2013, 11:30 PM   #14 (permalink)
I see how that could work... As long as the laptop never goes too low on the current draw or else the charger will shut off as the battery seems fully charged.
I have a Sony laptop...
Old 08-07-2013, 11:40 PM   #15 (permalink)
Truth! Had to replace a VIAO Z series hard drive (SSD). $1100 !!! Couldn't sit down for a week after that one
Old 08-08-2013, 12:07 AM   #16 (permalink)
Most charger will NOT charge if it see a low voltage or no voltage on the other end. In your case the other end is your laptop. (zero voltage). This is to prevent charging a dead cell.
Wiring up your two 3S pack in series maybe the only way to go.
Old 08-08-2013, 12:18 AM   #17 (permalink)
Another good point... if the pack voltage is too low... My charger will charge for a minute or two and then shuts off if the pack isn't at least 3V per cell.
2nd. without a battery hooked up... it won't even start charging...
Old 08-08-2013, 04:28 AM   #18 (permalink)
So I'm running off my 2 3S lipos in series and seems to be doing great. It's a little less convenient in that I'm using relatively small batteries (2100 mah ... I brought the 450), but hey, it's working, and with this method I'll be able to charge up the laptop battery for the trip home. I was ultimately concerned with dyuen888 and dcope17's points ... I'm plugging into the laptop, not the laptop's battery, so I don't think there would be any voltage there for the charger to see (again, no multimeter to check). Also, I've watched the voltage display on my charger when charging lipos and it's constantly switching off (on for a 5 seconds, off for 1, or something like that), presumably as its checking pack voltage. I figured that the laptop wasn't designed to see its power constantly being switched on and off.
Thanks all!
JR 11X
