Old 05-14-2013, 08:20 AM   #2081 (permalink)
When you strech to a 1000 or so, a motor will be to heavy and harder to make the cg when mount it on the tail g.box.
Make a 1.2m bomm and add just the tsil gear you will see that a few grams do a lot with your cg
SA1000E . MiniVolt-500.CncEfects: K7-1000E K6-800E. K700E.K550-600
Align:2x Trex 450 Dominator 6s. 2x Trex 550E 4× BeastX- 3× Vbar- 3× Spartan VX1n- 1× Sk720
runesb is offline        Reply With Quote Quick reply to this message
Old 05-14-2013, 09:11 AM   #2082 (permalink)
Originally Posted by R_Lefebvre View Post
Ok, so, many of the typical reasons to go with a DD tail. Then why not just put the motor right at the back as well? Are you planning aerobatics with this thing? Making the tail true direct-drive really simplifies things.
The tail assembly is a designed upgrade for 550/600 class birds and hopefully 700 class frame sets.
While also trying to improve on stretching capabilities by avoiding using the stock plastic parts if possible.
This setup is purely for AP, don't believe anyone would attempt aerobatics while carrying camera equipment and swinging 1000 mm ASYM blades.
The designed purpose for the separate tail drive is to compensate for the extremely low HS.
Keep in mind there are not many 1000 class birds flying , so this is for all intent experimental to gain better control, performance and integrity with what is available at present.
JR9303 / JR9503 / Futaba10CHP
Old 05-14-2013, 09:27 AM   #2083 (permalink)
If this is for AP as indicated, the CG should not be a problem. Putting the motor on the end of the tail might allow you to move the main batteries off of the boom, and put them back up front which is a much better way to go.
Ok, most of the same reasons I'm trying to do a DD tail as well. But I also want to get rid of all the nasty powertrain bits.
Now, where you have a massive advantage over my approach, is in motor selection. You can take advantage of a small gear reduction ratio, allowing for a higher KV motor. I can't. That's one thing that really sucks about the DD tail, is powering it is tricky.
Currently, I use 2x 4S packs for the main motor (8S), and a 2S pack for the avionics. HV servos direct with no BEC. There's no motor in existence that will spin ~7000 RPM on 8S. And trying to run on 2S would require massive amps to get the power the tail sometimes requires. So I'm kind of stuck. I have two options:
-Change to 3S with a BEC on the avionics, and use 3S on the tail motor which is a little better. About 600 KV motor will do the job.
-Stick with 2S on the avionics, and run the tail motor on 4S by tapping off the first of the main battery packs. This would be OK, except the fact that now one of the 4S packs will always drain faster than the other, which can cause a lot of problems.
Any other ideas?
-Rob
Former Managing Director of Maxxum Robotics Inc.
R_Lefebvre is offline        Reply With Quote Quick reply to this message
Old 05-14-2013, 09:49 AM   #2084 (permalink)
I wonder if this would work to run on 8S:
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
350KV on 8S should give 11760 RPM, correct? But that's at no load. It'll be a little lower with more load? How much might it drop typically?
Then I can run this ESC:
http://www.hobbyking.com/hobbyking/s...ler_OPTO_.html
This has AFW, so you can run it at reduced speed without it blowing up. Run it at 60% governor setting would get me 7000 rpm? Or maybe 70%? Should be totally fine, since I'm already running the main motor at 70% on a Hobbywing ESC and it's totally fine.
Maybe this is the answer. Only thing that sucks is that ESC is $108.
The other thing is that this motor is really only rated for 5S. But I think that the mag wire insulation isn't likely to actually break down at 33V. I think they only really rate them like this because on high Voltage, the potential to draw too much power is there. But if you manage that properly...?
It's rated for 1190 watts, but I don't expect it would ever go over 1000W, and typically would be at 100W.
One of my goals it to eventually get to the point where I have a DD tail, and a single belt reduction drive for the main rotor. No noisy gears or flappy tail belts anywhere in the system.
-Rob
Old 05-14-2013, 10:25 AM   #2085 (permalink)
I can not speak for anyone else..
But, I'm running 4 6S 5000 packs for a total of 12S 10,000mA powering the main drive motor along with a 2S 5000mA powering the electronics.
Add to that a solid motor/camera mount holding a Contour, along with a second mount with a GoPro all mounted to the extreme forward position as you can see below.
And I'm still a bit tail heavy...
The hope is to run the smallest motor/ESC combo possible on the tail drive.
At present, I can just barely hold tail control at 760 HS running 180mm tail blades, if Ibreach say 950 HS tail control is much better, but I'm not too thrilled running tail blades that large.
My logic says I should be able to achieve what I need by using a 450 class motor on 3S ( hopefully )
Your specific requirements for what your attempting will be a trial and error process much like mine.
In the end, it all turns out to be an exercise in experimentation and hopefully a working solution.
Old 05-14-2013, 10:54 AM   #2086 (permalink)
Wow, I can't believe that doesn't balance already. But, you could still move that other battery forward even more.
Anyway, was just wondering what your plans are as it's an unusual arrangement.
-Rob
Old 07-02-2013, 10:21 PM   #2087 (permalink)
Well kiddies....
Even here at Castle East.....we mere mortals fall to our own frailities.
Sorry to report that as of the time of writing this, the mad professoris now laid up in cardic icu.
Seem that all things need fixing now and again.
Looks like the lab will be taking a rest for a short time
Old 07-03-2013, 04:37 AM   #2088 (permalink)
So sorry to hear about this, Richard. I hope that you have a speedy and full recovery. You will be kept in our prayers. Definitely keep us posted on your progress!!! If there is anything we can do for you, don't be afraid to ask.
Aram
Trex 800e, Trex 600n
Futaba 14SG / AMA# 959345 / IRCHA #3954
aramb is offline        Reply With Quote Quick reply to this message
Old 07-03-2013, 12:55 PM   #2089 (permalink)
Stop scaring the crap out of me and get better quick, you hear?
Jerry
jperkosk is offline        Reply With Quote Quick reply to this message
Old 07-03-2013, 01:48 PM   #2090 (permalink)
Get well soon
mhoebrec is offline        Reply With Quote Quick reply to this message
Old 07-03-2013, 11:22 PM   #2091 (permalink)
Sorry to hear about your trip to the repair shop. I wish you the best and a speedy recovery!
When in doubt, easyify & over-simplificate.
Superhornet is offline        Reply With Quote Quick reply to this message
Old 07-07-2013, 02:38 PM   #2092 (permalink)
Default M.I.s = Not Good.....But
My thoughts are with you. Always been a fan of your work and creativity. Now, having done that bit myself on May 4, I went down jogging. I can't tell you exactly what to expect, but I can tell you what happen to me. First of all, and you probably figured this out by now, if they mention cardiac rehab or stress test, go shave all of the hair off you chest. If you don't get rid of it, they will by pulling it out with those adhesive electrodes. The stress test is not that bad, but you will sweat some. Up hill at 14 degrees on a treadmill, till they say stop.
Cardiac Rehab is not that bad ether, you work out 3 times a week with other people in the same boat as you. They will probably test you for sleep apnea, major pain the the butt. If they ask you if you are depressed about the event, I just told them, no I just want to go fly After all its a beautiful day out there.
mbutler6063 is offline        Reply With Quote Quick reply to this message
Old 07-07-2013, 07:51 PM   #2093 (permalink)
Get well soon!
N3M0 is offline        Reply With Quote Quick reply to this message
Old 07-08-2013, 09:37 AM   #2094 (permalink)
Well it took a double bypass and a hole between 2 chamberss
to get this mad doctor patched up.
Now it's time to recover
Old 07-08-2013, 09:42 AM   #2095 (permalink)
Default Get after it
and do exactly what they tell you to.
Good luck, keep us updated please.
Old 07-08-2013, 02:19 PM   #2096 (permalink)
Best wishes for a complete and speedy recovery!
Rob D.
nocontrol1 is offline        Reply With Quote Quick reply to this message
Old 07-08-2013, 08:20 PM   #2097 (permalink)
Heal quick and keep your hands off these young nurses
Jerry
Old 07-13-2013, 11:01 AM   #2098 (permalink)
Well Night, for once you will have no choice but to follow somebody else's orders. You do precisely that. You have had some serious "mods" done. Take it slow and easy!
MQX Quad,Align 550E/NazaH/GPS,Align450 Pro/CPII, Flame Wheel F450 Quad NazaM/GPS/GoPro3, Blade 350 QX/ GoPro3
Never lend money. It causes amnesia.
Stumblebee is offline        Reply With Quote Quick reply to this message
Old 07-24-2013, 09:17 AM   #2099 (permalink)
New toys... you gotta love em'...
Everything you LOVE about PowerLab in an ALL NEW Dual, Independent Channel Battery Workstation with a whopping total output power of 2688W!
PN: LC08S40ADIC-MC-US
Cellpro Dual PowerLab 8x2 with dual EC5 input cables, 2688W, Multichemistry Battery Workstation. AVAILABLE LATE SEPTEMBER, 2013. TAKING PRE-ORDERS MID AUGUST, 2013. The industry's highest output power rated Battery Workstation. Independent channel operation, 1344W per channel, 2688W total using 40V input. Intuitive PowerLab interface. Designed with built in PowerLab reliability and quality.
Old 08-05-2013, 02:13 PM   #2100 (permalink)
Well considering that for me at least this flying season is pretty much a complete bust.
I ended up going over every machine I have.
I did manage quite bit of preventative maintenance, also going through the wiring and insulating any possible area's that may pose a shorting issue.
Also going through all the different setup making sure all were working as they should.
side note to self: I really need to unify these machines to one possibly 2 operating systems, Just way too many installed now and it does get confusing.
So for the foreseeable future, the major part of the Castle East fleet is grounded until such time as to when I can actually pick them up and carry them.
So until then I'm left flying the fleet of 450's and micro's that are here.
