Old 04-24-2011, 11:45 PM   #1 (permalink)
Default Need Tail Help - Not holding
Hello,
I am having issues with my Outrage Velocity 50...
I recently set up my helicopter to be flybarless - that part seems to be working fine.
However, the tail upgrade does not seem to be working correctly. What should I do to properly configure and set it up? Is there a Finless video on this? One friend told me I may need to use some sort of mix on my radio.
I am hoping to get this working properly for the next XFC so I can perform the 100% tail in funnel:
https://www.helifreak.com/showthread.php?t=300287
ID:	224123   Click image for larger version
-Austin
H
elifreak Special Bacon Awareness Committee
Wurger is offline        Reply With Quote Quick reply to this message
Old 04-24-2011, 11:46 PM   #2 (permalink)
Did you balance the paddles? Perhaps KBDD paddles will be the cure?
Andy.Kim is offline        Reply With Quote Quick reply to this message
Old 04-24-2011, 11:46 PM   #3 (permalink)
I think that as long as everything is mechanically centered, and your linkages in the tailrotor are of equal length, you should be good. Is the tailrotor tracking properly?
A.D.
ADozer is offline        Reply With Quote Quick reply to this message
Old 04-24-2011, 11:47 PM   #4 (permalink)
Wurger,
I can see one problem right away-shouldn't you have KBDD Paddles on that assembly?
Old 04-24-2011, 11:50 PM   #5 (permalink)
Well for starters.. the tail rotor flybar paddles must swing upwards into the rotor wash, you have them on backwards.. Hopefully you've removed the gyro at this point, it is not needed anymore. it should look similar to the tail on my 90.. it holds incredibly well.. far better tail stability than when I used electronics.
Team Tail-in / Helifreak Elite Bacon Awareness Committee
RotaryBliss is offline        Reply With Quote Quick reply to this message
Old 04-24-2011, 11:51 PM   #6 (permalink)
I assume you actually installed the blade bolts before spooling up, right?
I seem to recall that particular upgrade requires trailing edge control, not leading edge as shown in your pictures...
-Kevin
Skiddz is offline        Reply With Quote Quick reply to this message
Old 04-24-2011, 11:52 PM   #7 (permalink)
good catch
Old 04-25-2011, 12:03 AM   #8 (permalink)
well there's ya problem right there.
your paddles are on backwards.
I think you should go with flybarless paddles, they'll work a lot nicer.
AMA#1058309
Mon_t is offline        Reply With Quote Quick reply to this message
Old 04-25-2011, 12:09 AM   #9 (permalink)
fly barred tail blades are no longer needed now either.
Team Fun / Heli Canada
**When you start to be in complete control reflexes are not a requirement.**
s0laris is offline        Reply With Quote Quick reply to this message
Old 04-25-2011, 12:14 AM   #10 (permalink)
Okay I worked on setting it up a little more... I hope to test it and have it working in the next few days.
-Austin
H
Old 04-25-2011, 12:16 AM   #11 (permalink)
You've still got your bloody paddles on bass-ackwards!
-Kevin
Old 04-25-2011, 12:18 AM   #12 (permalink)
How do I fix that? I really want to get this working ASAP!
-Austin
H
Old 04-25-2011, 12:21 AM   #13 (permalink)
Man, You are so old school....every body's going flybarless tails now.....
Compass 6HV, TotalG, BLS251, DX7S.
Kasama Srimok, Scorpion HK-4525-520KV, TotalG, BLS251, DX7S.
...and the rest...
Corrari is offline        Reply With Quote Quick reply to this message
Old 04-25-2011, 12:21 AM   #14 (permalink)
OK, easy.. You'll need a vice and a big pair of pliers ... (You can substitute a friend with his/her own set of big-ass pliers fo the vice if you don't have one)
Stick one paddle in the vice and clamp it down securely with the TR flybar vertical. Now grab the other paddle with the pliers. Grab the nose of the heli and swing it 180 degrees. Remove the pliers and unclamp the vice. Go fly.
-Kevin
Old 04-25-2011, 12:22 AM   #15 (permalink)
I think the gain is too high
Old 04-25-2011, 12:24 AM   #16 (permalink)
with the flybarred tail there is no gain.. or gyro for that matter...
Old 04-25-2011, 12:27 AM   #17 (permalink)
Thanks! That flipped them over!
ID:	224134   Click image for larger version
-Austin
H
Old 04-25-2011, 12:27 AM   #18 (permalink)
sounds like there isn't enough gain
Old 04-25-2011, 12:30 AM   #19 (permalink)
Better, but you appear to be missing one blade bolt... You could probably get by with a bent paper clip or maybe CA a toothpick or shish-ke-bob skewer in there..
-Kevin
Old 04-25-2011, 12:30 AM   #20 (permalink)
He's trying to gain tail control.. is that what you mean?
Tags
align, fly bar, flybarless, outrage, upgrade
