Synergy Model Helicopters Synergy Model Helicopters Support |
04-07-2012, 01:23 AM | #1 (permalink) |
Synergy E6/7 TT Conversion - Official Information Thread
Below is what comes in the TT Conversion kit, it's essentially an entirely new front and rear transmission. The below parts comprise more than 1/3 of the entire helicopter.
TT Conversion Parts list - CF Vert Fin - TT E7 1pce (yes, this conversion requires a new CF vert fin) 18T Front Trans Bevel Gear 1pce (machined delrin gear) 18T Front Trans Mushroom Gear 1pce (machined delrin gear) 20T Bevel Gear - E7 1pce (machined delrin gear) 20T Bevel Mushroom Gear - E7 1pce (machined delrin gear) 12T Spur Gear 1pce (CNC hard coat aluminum gear) 54T Spur Gear 1pce (machined delrin gear) TranSupport Standoff 6pcs Front Mushroom Gear Bearing Block 1pce Bevel Gear Top Bearing Block 1pce Spur Gear Bottom Bearing Block 1pce Tail Box 1pcs Tail Box Plate Left 1pce Tail Box Plate Right 1pce Tail Box Plate Spacer 1pce Output Shaft Spacer 1pce Tail Box Bearing Spacer 1pce 2mm Bevel Gear Pin 2pcs 2mm Spur Gear Pin 1pce Spur Gear Shaft 1pce 6mm Tail Output Shaft 1pce (included for those who run bent tail output shafts and dont know it) 6mm Shim 1pcs Tail Bell Crank Mount 1pce Spur Gear Hub 1pce (this is a very nice cnc hub to support the 54T Spur Gear) Jesus Bolt Collar 1pce Torque Tube E7 1pce Torque Tube E6 1pce (yes, you get a TT for your E6 if this is the way you decided to build the kit) Torque Tube End 2pcs Torque Tube Bearing Housing 2pcs O-Ring 4pcs 6x13x5 Radial Bearing 2pcs 8x14x4 Radial Bearing 2pcs 12x18x4 Radial Bearing 4pcs 5x9x3 Radial Bearing 3pcs 5x10x4 Radial Bearing 1pce M3x6 Set Screw 1pcs M3x12 Set Screw 3pcs M2x10 Socket Head 2pcs M3x6 Type 1 Cross Recess 4pcs M3x6 Button Head 27pcs M3x8 Button Head 6pcs M3x10 Button Head 3pcs M3x30 Socket Head 1pcs M3x8 Socket Head 1pce M2 Regular Nut 2pcs M3 Nylock Nut 1pce M3 Washer 1pce The E6/7 TT Conversion Kit Retail Price is $199.00. Dealers and distributors will not be happy because I had to remove all of the margin in order to keep you, the customer, happy with the final price. Release date - The CNC shop is trying to ship TT Conversion Kits next week 4/9 - 4/13. I will keep you posted as to whether that happens or not. I know the wait has been long but the drive system is right and I think you will be happy with it. Let me know if you have any questions! Thanks, Matt |
04-13-2012, 05:25 PM | #2 (permalink) |
Matt,
Can you post some pictures of these new parts? TIA Manny |
04-24-2012, 06:48 PM | #4 (permalink) |
anyone have the manual that will come with it?
04-24-2012, 07:43 PM | #5 (permalink) |
Team Rail blades, Team Scorpion motors, V-Team |
04-24-2012, 08:01 PM | #6 (permalink) |
Doesn't seem like an overly complicated upgrade. I look forward to the install.
Synergy Factory Specialist / Rail Blades / Team Scorpion |
04-26-2012, 04:58 PM | #8 (permalink) |
Yeah seems straight forward.
04-27-2012, 12:29 PM | #9 (permalink) |
Guys, please pay close attention to the set screws that retain the bevel gear pins! The one at the tail box may be missing from your kit, so be sure to add one. If these set screws are not installed, you WILL lose a bevel gear pin in flight!
05-07-2012, 01:04 AM | #10 (permalink) |
TT spur gear
Need just the TT drive gear stripped mine.
320-154 54T Spur Gear
Team MikadoUSA Team Scorpion Logo 800,700,600,400,Diabolo,TDR |
05-10-2012, 06:43 PM | #11 (permalink) |
How did you strip them on a crash?
...Once upon a time there were Nitros, flybars & frequency pins...Shawn |
05-15-2012, 06:37 AM | #12 (permalink) |
If you crash can you buy just replacement parts or do you have to buy a complete conversion again?
05-15-2012, 07:08 AM | #13 (permalink) |
Fblrotors.com has the parts. I am sure others do as well.
06-16-2012, 03:16 PM | #14 (permalink) |
Is it only one set screw to hold the tail boom in?
06-16-2012, 04:37 PM | #15 (permalink) |
you could do 3 if you wanted one on each boom clamp and on the tail!!
06-16-2012, 07:09 PM | #16 (permalink) |
No, the boom slides into two clamps which actually hold it in place the set screw is just insurance. The tail box also has one built in clamp and one place for a set screw. These are metal clamps, not plastic, and would hold the boom and tail box in place just fine without the 'insurance' set screws.
Synergy E7, Vbar 5 Pro, BLS255 & 256HV, Hacker Turnado 530 Edition, Rail 716, CC120, WR Sup BEC, Scorp BUG | Trex 450L, Vbar Pro, MKS 8910A+ on tail, Talon 35 | Futaba 18mz |
07-04-2012, 04:16 AM | #17 (permalink) |
Do I really need the TT? I don't want to get into discussions of belt vs TT. It's been done so many times and it's boring now. I'm more interested in specific issues with this heli.
Are there any specific issues that the TT kit solves? Is it required to do a static mod with the belt version? Is the TT version a lot noisier and less smooth than the belt version? Any other reasons why I should get the TT version?
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl |
