Go Back   HeliFreak > R/C Helicopter Support > Multi Rotor Helicopters
Multi Rotor Helicopters Multi Rotor Helicopters Info and Support - Tandem, Quadcopters, Tricopters, Octocopters, and Hexacopters
Old 10-23-2012, 01:37 PM   #1
petedee
Default GoPro WiFi and 2.4Ghz radios.
Has anyone seen any interference issues at all?
Pete
TBS Discovery, TBS Discovery Pro, Spanky250, Q400-X
DX18,14SGH
"I like rice. Rice is great if you're hungry and want 2000 of something."
-- Mitch Hedberg
petedee is offline        Reply With Quote
Old 10-24-2012, 02:04 AM   #2
petedee
Good to hear no one is having problems, my flights with the GoPro with wireless have been fine so far.
DX18,14SGH
-- Mitch Hedberg
Old 10-24-2012, 09:50 AM   #3
oosnoopy
Digital video messages and digital radio packets are not likely going to cause much trouble. It's an analog video signal that will case issues.
Your range probably limited to less than 50m however, if you go to a longer range FPV system, you'll want to hit 1.2 GHz or 5.8 GHz
oosnoopy is offline        Reply With Quote
Old 10-25-2012, 12:40 AM   #4
petedee
Not doing FPV as such but use it to do a little monitoring and I have not had a problem with my setup but was wondering if other people experiences were the same as mine.
Pete
DX18,14SGH
-- Mitch Hedberg
Old 10-25-2012, 05:14 PM   #5
oosnoopy
Yeah you're in the clear. The channel use by most SSFH radio's is quite small, and the good ones will hop channels if things cloud up). 2.4 GHz should be trouble free for your GPS too. I've seen longer GPS lock times from unfiltered 900Mhz and 1200 Mhz communications.
Old 10-28-2012, 01:02 AM   #6
petedee
Do you know if that applies the same top the GoPro remote?
Thanks.
Pete
DX18,14SGH
-- Mitch Hedberg
