Old 01-25-2013, 11:09 AM   #61
HeliFX
Vlad nice work on the Knipex and yes expensive suckers.
It took me a few days to work up the nerve to grind down a perfectly functional plier
DIABOLO 1 & 2: PYRO 6+7 YY (built by HeliFX),MKS, Vbar 5.3 + YGE160HV, JR 11X DMS ||
GOBLIN 570: HKIII4025 1.5mm YY Kv 1080
(built by HeliFX),
JR 8917HV, Vbar 5.3, Heli JIVE v13
HeliFX is offline        Reply With Quote
Old 01-25-2013, 12:36 PM   #62
belcom
Thanks. Well, I did not quite put it on the grinder right away myself. It was hard to commit to it but I knew it had to be done. The small Dremel grinding wheel was key to finishing it off perfectly before sanding. And its best to have the dremel in a fixed position while holding the pliers in both hands. The dremel drill press would be perfect but I have yet to purchase that accessory.
Team Compass
belcom is offline        Reply With Quote
Old 01-25-2013, 12:48 PM   #63
HeliFX
have a dremel myself but had access to a drill press so took very little time
money and effort well spent I'd say.
(built by HeliFX),
Old 01-26-2013, 04:57 PM   #64
Todd Moriarty
I modified a pair of jewelers wire wrapping pliers to help reach down the stator a bit. Polished them to 1500 grit, and smoothed off all rough edges
one other invaluable set of tools. A gunsmith's punch set, including a G10 large diameter punch that is great for tightening up the winding groups
Todd Moriarty is offline        Reply With Quote
Old 12-21-2013, 04:10 PM   #65
modomains
Smile Stator
I hold the stator with a vice. Using my hand feels awkward.
Also, my favorite tools are Knipex. But I shop regularly at http://www.kctoolco.com/Knipex-Tools-s/2506.htm.
modomains is offline        Reply With Quote
Old 09-20-2014, 04:15 PM   #66
omerco
Well as i have no idea how to get Knipex here, This is the tool i have made. Bought the original at a jewelers tools shop and modified it. working very well i have to say (parallel close).
ID:	537230   Click image for larger version
ID:	537231   Click image for larger version
X7 | Scorpion 4525 Ultimate | scorpion 160HV esc | Mks servos | SK540 | Edge 713| Logo 600 3D | Pyro 450 | Castle 120HV | Mks | SK540 | Trex 450 V2 - 4S Stretch | K-Force 45 | SK540 | Trex 600EFL | Yep 120HV | SK540
Skookum Robotics Support Pilot
omerco is offline        Reply With Quote
Old 09-20-2014, 04:19 PM   #67
HeliFX
Those are perfect.
The only thing they can bend over extensive use
(built by HeliFX),
Old 09-20-2014, 06:01 PM   #68
omerco
Its steel made. i checked it doesn't deform. bends just tiny bit under pressure which is good because it kind of sits itself well on the coils/wire.
