Go Back   HeliFreak > R/C Helicopter Support > Audacity
Audacity Audacity Pantera Helicopters Support
Old 11-11-2015, 08:32 AM   #1 (permalink)
Default Larger Pantera
Hi
Someone ask me if the Pantera came in a larger like 700-800 size nitro. Just wondering what was available. Thanks
boss5horse is offline        Reply With Quote Quick reply to this message
Old 11-11-2015, 11:56 AM   #2 (permalink)
No, we don't sell that size heli. We do offer a stretch conversion but it's intended ONLY for scale applications and isn't rated for 3D type high-RPMs rotor speeds. We're very careful to make the distinction when folks inquire.
Anyway, yes, we offer an FBL head, an FBL-conversion (which is very inexpensive), as well as the Quattro head, which by definition is FBL. However, in general we tend to stick to our knitting, which is with the 600-class machines instead of the 700-800 size models. The point is we only stretch them for low-RPM scale use.
Basically, we view 600-class models as representing the 80/20 rule in practice. E.g. where 600-class models are 80% of the market and 700-800 are the 20% segment. Why? Principally for the simple reason that crash costs go from $40-60 plus blades for a Pantera to $150-300 plus blades when you're flying something like a 700-class Goblin or T-Rex. It's just physics.
Add to this, it's also because in our experience 600-class models are large enough to handle strong winds while smaller models really don't (of course 700-800 class models handle wind even better, but 600 class handle it well enough). Meanwhile, smaller models, e.g. 500-550 class and smaller are often grounded by the wind. Hard and fast rules? No, of course not - but nevertheless - a fair generalization. Does this mean we'll never offer a 700-800 size model? No, but don't hold your breath.
John Beech - GM (and janitor)
www.promodeler.com
407-302-3361
AMA # 47381, IRCHA #745
jbeech is offline        Reply With Quote Quick reply to this message
Old 11-11-2015, 12:18 PM   #3 (permalink)
Default Larger pantera
Ok thanks John. Had someone ask me that after he seen mine. Thought I would throw it out there. Thanks again
Old 02-17-2016, 01:02 PM   #4 (permalink)
Audacity offers a flybarless head from the factory? I was going to redneck convert my current heads when I'm ready for FBL. I'm just so happy with the flybars to care right now.
On a separate issue I'd like a easier way to mount a gyro plate above the elevator servo. I made Swiss cheese out of my new P6 frame trying to drill a hole for a spare plate. I current use a CSM cyclock which needs to be close to the swash servos.
Is there a technique to mounting things (gyro/battery plates, tanks, switchs etc) sandwiched between the main frames but you have to drill and pray from the outside of the frame?
Garland is offline        Reply With Quote Quick reply to this message
Old 02-18-2016, 06:57 AM   #5 (permalink)
If you put a 10mm 700 class aluminum head on it (e.g. RJX, 7HVU, Frenzy .90) would 3D headspeeds then be safe or is there some other fundamental reason why high headspeeds are unsafe with a stretch?
Old 02-18-2016, 08:04 AM   #6 (permalink)
Correct, there is no fundamental reason for not doing this. That said, we may get around to doing this ourselves (once we remove some of the irons we have in the fire) because intrinsically, the P6 is a 700-size model (physically). And FWIW, I've always felt this to be a Pantera advantage because newbie pilots (whom, due to a lack of experience, have special trouble with orientation at a distance) are especially helped by its larger size.
Consider; a P6 is considerably bigger than the average T-Rex 600 or Goblin 520. This translates into an edge - precisely - when it's most important. Think back to when you were learning to fly, would you agree getting too far away to see clearly is not exactly an uncommon situation for a beginner to find themselves in upon occasion?
www.promodeler.com
407-302-3361
Old 02-19-2016, 04:17 PM   #7 (permalink)
I have an RJX flybarless head on a Pantera.
MartyH is offline        Reply With Quote Quick reply to this message
Old 02-19-2016, 05:24 PM   #8 (permalink)
That's a decent head. Several pilots I know use them.
www.promodeler.com
407-302-3361
Old 02-19-2016, 05:43 PM   #9 (permalink)
The 50 or the 90? The 90 comes in two versions one for a 12mm shaft and one for a 10mm shaft.
The 10mm version uses an M3 jesus bolt and should install on the P6 mainshaft with no problems.
The 12mm version is designed for the Trex 700 as it uses two m4x8 screws on either side of the hub (it doesn't utilize the lower unthreaded hole on the Trex 700 mainshaft) and you will run into difficulty if you need to install it on a 700 that doesn't have threaded holes in the mainshaft because the recess for the screw on each side of the hub is designed for a screw head. You would neet to put a washer on one side and use a longer jesus bolt and a nut driver to install it on a mainshaft that doesn't use a threaded bolt hole. The 12mm also comes with a larger washout base and longer swash driver arms (the plastic radius arms are the same and are in fact the same ones that RJX uses on their 450, 500 and .50 heads)
Old 02-19-2016, 07:42 PM   #10 (permalink)
Default New p6
I have a new P6E. It's a flyLESS. After I built it I flew it once and put it on the shelf. Loss of time for it right now. I just had to throw that in there. Lol
