Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion |
07-12-2012, 08:23 AM | #1 (permalink) |
Fusuno Green canopy
Hello. 2 flights today and the canopy stays have ground a hole in both sides near the motor. Anybody else had this ?
James. Sent from my HTC Incredible S using Tapatalk 2 |
07-12-2012, 09:44 AM | #2 (permalink) |
Yes..RC Booya has pads to install on the insdie of the canopy for this...another fix is to take the skids stops that are provide with kit, and put them over your canopy standoff, leaving them sticking out just a little...
#1 - Compass 7HV, Scorpion 4530 , VBAR, Kosmik 200 #2 - Logo 700 |
07-12-2012, 09:48 AM | #3 (permalink) |
My front canopy standoffs came with rounded inserts installed in them. They are skid pipe ends I believe.
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX TT E-620 SE x 2: Scorpion 4025-740 200srx, nano qx JR Parkmites x 2 |
07-12-2012, 03:45 PM | #6 (permalink) |
James, been using the skid olive/grommet mod since day 1, zero issues. That does look bad though! You still got the stock ??
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep |
07-12-2012, 03:51 PM | #7 (permalink) | |
still have the stock, just tested and there is a 1mm gap between the stand and the canopy. FL are going to send it back for me and hopefully replace it. James |
07-12-2012, 04:04 PM | #8 (permalink) |
The rubber skid grommets, just slide 1 over the stand off, leaving a bit over hanging
07-12-2012, 07:45 PM | #9 (permalink) |
I use mine as they are stock with no wear on canopy.
Do you maybe have a high freq vibe causing the damage? Does your tail fin vibe?
07-16-2012, 11:57 PM | #10 (permalink) |
ok , get yourself some fibercloth and some epoxy and beef up the inside spot a little to fix it... then stickers on the outside to keep the paint from fracturing , then , do the mod to the standoffs.
mine , i jsut have the skid ends in not wearing at all , but stock cano...(same one, as fusano makes the cano's). something else i did was the bottom mount(plastic insert thing) , i wrapped a piece of velcro strap wedged between the carbon mount , and plastic skid , then have a velcro sticky back on the canopy , really locks the canopy onto the heli securly.
Warp, 6HV LED,6HV, Alien 450 MR, 250 mini Quad racer(4s monster) FPV rules the roost! |
07-17-2012, 02:59 AM | #11 (permalink) | |
if they make the canopy then they made a very bad copy on this one its a completely different shape from the stock one. I will how ever do the stand off mod you suggested lets see what Fast-Lads say when I take it back on Friday ??? James. |
07-18-2012, 12:34 PM | #12 (permalink) |
I've been running my green Fusuno Future since last September, and have easily over 100 flights on it. Others who've recently seen it can attest it's like new.
My setup? Simple. See Mr. BBRFST's solution. I followed his lead. https://www.helifreak.com/showpost.p...0&postcount=12 For additional protection, simply apply some Shoe Goo, or Goop adhesive to the inside of the canopy where the standoff touches. This will reinforce the fiberglass and cushion the action of abrasion from rubbing between the two. Best wishes,
= Rb43 = |
07-18-2012, 05:18 PM | #13 (permalink) |
I attest!
Scott
Spartan Vortex Inside,Team Scorpion KBDD Team Pilot ):> |
07-18-2012, 05:29 PM | #14 (permalink) |
Thx!
= Rb43 = |
07-23-2012, 04:27 PM | #15 (permalink) |
I'm running the same green fusuno canopy with just the skid pipe ends in and have no wear issues like that at all. I'm not even using anything extra on the pipe ends. I'm wondering if the bracket in your canopy is not mounted far enough in to keep it from moving once the standoffs are secured.
Team Synergy VP Racing Fuels Team Scorpion |
07-24-2012, 04:37 AM | #16 (permalink) | |
