Go Back   HeliFreak > R/C Electronics Support > Castle Creations ESC and Software
Castle Creations ESC and Software Castle Creations ESC Software and Hardware Support
Old 07-26-2012, 03:40 PM   #21
Blayd
Been there, done that.....I also emailed them, but I almost never get a response.
Trex700N2E
Trex500ESPTT(PRO head and Tail )
Trex500ESP (Belted)
HC500SE ....GO TEAM FLYBAR!
Blayd is offline        Reply With Quote
Old 07-26-2012, 04:00 PM   #22
itbvolks
Same - plus a call.
Hoping it gets sorted. Otherwise, running fine. More a nuisance than a real problem....
itbvolks is offline        Reply With Quote
Old 07-26-2012, 07:52 PM   #23
Blayd
Yeah, true.... they are stuttering.. but do start, and run great... Just not completely sure of the consequences of the constant stuttering start on the motor or the ESC...
Trex700N2E
Trex500ESP (Belted)
Old 08-11-2012, 05:20 PM   #24
davehour
Well, to the original question, is it save to upgrade to v4.01?
I have a T-rex 600EFL Pro; all stock.
David
T-Rex 700E Pro DFC, Spirit FBL Unit, Futaba R6303SB/8FGHS
Blade mCPx 140mm boom, DX7
RealFlight 7
davehour is offline        Reply With Quote
Old 08-11-2012, 09:15 PM   #25
Blayd
Seems like the 600's are doing well on 4.01.. I just went back to 3.27 on two of my ICE 100's running the Scorp 1900kv motors..( bad stuttering ) the ICE 100A I use with a 1400kv Scorp is running great on 4.01.
Trex700N2E
Trex500ESP (Belted)
Old 08-12-2012, 02:32 PM   #26
davehour
Hi,
I tested v4.01 today in my 600EFL Pro. It worked fine. I did follow the recommendation of using a higher value for the Initial Spool Up Rate from the recommended value of 59 to 65. It's worked fine and I believe I can set it to 59.
I had to reduce the governor gain from the recommended value of 15 to 14 because I could hear some noise in the gears.
One thing that surprised me is I set IDLE 1 to 2246 and IDLE 2 to 2358, and the system was able to maintain 2358 fairly well, even with the small head room it has using that headspeed. I checked the log and the power output wasn't clipped much, just in some occasions.
I'll keep flying the heli and if I find something else, I'll post the findings.
Thanks.
David
RealFlight 7
Old 08-13-2012, 12:06 AM   #27
Emurzion
@Davehour are you running the stick 600MX motor with the 600EFL.
Let us know if the default start power works for you.
I'm really getting close to update my esc. I'm getting slight noise from my motor also at 15, but I'm also using 3.27 firmware.
Emurzion is offline        Reply With Quote
Old 08-13-2012, 09:00 AM   #28
davehour
Yes, the 600EFL is all stock.
I'm using the Gens Ace 3300 6S 25c packs.
Governor headspeeds: 1903, 2246 & 2358.
Following are two graphs of one of the flights: The first one is a graph of the voltage, current and ripple voltage. The second one is a graph of headspeed, power output & temperature. I've also included a picture of the ESC settings.
David
Name:	600EFL Stock v4.01 Gov Graph 1.jpg
ID:	340122   Click image for larger version
Name:	600EFL Stock v4.01 Gov Graph 2.jpg
ID:	340123   Click image for larger version
Name:	600EFL v4.01 Settings.png
RealFlight 7
Old 08-15-2012, 02:42 AM   #29
Emurzion
Will our motor start up with the default value of 59?
Old 08-15-2012, 08:07 AM   #30
davehour
I bench tested at 59 and seems to work ok. I'll test flight it on this week and will report how it did.
David
RealFlight 7
Old 08-15-2012, 10:56 PM   #31
Emurzion
I updated and used all the values on the castle site except for my gain at 14 and rpm running at 2100, 2200, and 2300.
Im only losing about 300 rpm on hard transitional movements.
I love it!!! Thanks for all the help.
