Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters > Esmart
Esmart E-Sky Esmart
Old 02-03-2009, 08:33 AM   #41 (permalink)
I am happy with the push pull set-up.
Design Engnr is offline        Reply With Quote Quick reply to this message
Old 02-03-2009, 07:05 PM   #42 (permalink)
the push pull is actually pretty slop-free so it doesnt really need changing, but somepeople miht think otherwise.
MSR-X, Nano CPX, Belt CP Metal Edition w/g10 DTS align compatible frame, Trex 450 pro v2 w/metal upgrades, TREX 550e v2 w/ kde upgrades.
CUSTOM CNC MACHINING... Inquire within.
onehot69stepside is offline        Reply With Quote Quick reply to this message
Old 02-03-2009, 10:27 PM   #43 (permalink)
DTS is too hard on servos even on mg's, I don't see the difference in performance or advantage between the logo 500 3D and the outrage 550(I think the outrage 550 is a better performer.) Just redesign the way how the actuator arms(aileron) are mounted on the frame, I think it's pretty weak and if you can incorporate a longer battery tray up front for better CG. A silver 2mm CF of GF material will be nice.
_____________________
Scott's Hobbies
DVS inc.
damyxz is offline        Reply With Quote Quick reply to this message
Old 02-04-2009, 07:59 PM   #44 (permalink)
i cannot find BLACK garolite 2mm thick, which is about 3/32. All i can find is 1/16 and 1/8 in black. The only color in 3/32 i can find is brownish green, your basic circuit board color.
Im thinking that 1/8" is a little too thick.
Old 02-04-2009, 08:22 PM   #45 (permalink)
If i use the .060 g-10 that i use on the belt frames, the only advantage over the stock aluminum peices would be impact resistance. The minute force that would bend the aluminum frames wouldnt break the g-10. It would take a harder crash to break the garolite. HOWEVER, the .060 g-10 would be more flexible and could possibly result in a flimsy frame.
How thick are the esmart CF frames?
Old 02-04-2009, 09:21 PM   #46 (permalink)
The E-smart CF frames are OK and flexes a little on the lower bearing area and the tabs where the elevator arms attach. How about silver texalium material in 2mm or 1.6 mm?
Scott's Hobbies
DVS inc.
Old 02-04-2009, 10:14 PM   #47 (permalink)
how thick are the cf sides, are they 1.45 mm like the aluminum?
Old 02-04-2009, 11:18 PM   #48 (permalink)
texalium is really cool and actually pretty decently priced but i still cant find anything that thick.
Old 02-05-2009, 12:55 AM   #49 (permalink)
the stock frame is 1.6mm
I like the push/pull set-up myself, works good and I like all my servos in the same place
nuttcaze is offline        Reply With Quote Quick reply to this message
Old 02-05-2009, 01:31 AM   #50 (permalink)
just found some .093". thats 2.3 mm thick, still a little on the thick side but i think it would be better thicker than thinner. Im going to cut one from the .060 g10 and kind of get a feel for the flimsiness.
Old 02-05-2009, 01:48 AM   #51 (permalink)
The stock CF frame is 2mm. I just measured it with my digital caliper. My trex 600 CF silver frame is 1.6 mm. Maybe if you make some of the frame lightening cut outs smaller and retain more material, you can use a 1.6mm texalium and the frame will be stiff as the stock CF frame and might end up being lighter. Reduce the size of the cut outs on the upper frame especially in the area where the bell cranks are mounted. Reducing the size of the holes on that part will also give an option to place a third bearing block for added stiffness. Can you post a sample CAD drawing?
Scott's Hobbies
DVS inc.
Old 02-05-2009, 02:01 PM   #52 (permalink)
Im drawing the inside cuts today but i will post them up as soon as its finished.
Texalium isnt as stiff or strong as carbon fiber So i dont think that would work. All texalium is, is a regular fiber glass woven cloth that has been coated on side with silver. The silver adds no strength and is purely cosmetic,
Old 02-05-2009, 05:15 PM   #53 (permalink)
I wonder where align and outrage source their silver GF frame(texalium). The silver airframe would look awesome on the E-smart. Anyway, 2mm black G10would also be good.
Scott's Hobbies
DVS inc.
Old 02-05-2009, 06:16 PM   #54 (permalink)
the problem is i cant find anything in 2mm. I found texalium in 1.5 mm and 2.7 mm. And ive found g10 in 1.5 mm and 2.37mm. 2.37 will definitely be strong enough but it just seems like overkill and will make it bulky
Old 02-05-2009, 06:24 PM   #55 (permalink)
ive emailed a company to see if they can make it. They Have A LARGE assortment of colors.
Old 02-06-2009, 02:19 AM   #56 (permalink)
SOMETHING TO LOOK AT!
Ive done what damyxz suggested and took 8mm out of the front of the gear and tail gear cutouts as well as added more beef to where the bell cranks mount.
Any body have any other suggestions. And i think i will add in holes and material for the extra bearing block
Name:	ESMART UPPER EXTRUSION-Model.jpg
ID:	80730   Click image for larger version
Name:	Copy of esmart upper-Model.jpg
Old 02-06-2009, 05:33 AM   #57 (permalink)
Default With bearing blocks
Heres the design of the upper with the bearing block holes and material added.
Let me know what you all think.
Name:	esmart extrusion-Model.jpg
ID:	80734   Click image for larger version
Name:	esmart upper-Model.jpg
Old 02-06-2009, 07:17 AM   #58 (permalink)
That's really nice, One last suggestion, can you leave out or make the cutouts smaller above the gear hole.
I'd rather have less flex in that area than the frame being light. To give you an idea...my e-smart's RTF weight with CF frame and metal parts, 6S 5000mAh batt, 2S lipo receiver pack and modified Trex 600 skids is 6 lbs, 9 oz.
Scott's Hobbies
DVS inc.
Old 02-06-2009, 03:06 PM   #59 (permalink)
ok now that i think about it, what the heck. Ill just make the holes small enough just to get an allen in there.
Ive never had to change a main gear, when you guys change your main gears, do you use these holes to get tools in there to remove the sleeve?
Old 02-06-2009, 03:26 PM   #60 (permalink)
here it is with smaller cutouts near the bellcrank locations.
Name:	esmart upper smaller cutouts extrusion-Model.jpg
