Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600 PRO Class Electric Helicopters
600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 04-09-2013, 11:44 PM   #1 (permalink)
Default changing 3.85 to 4.5 ratio
Any of you guys running the old 4.5 gear ratio on your 600 pro? was interested in changing the gears out but wanted to get some input on how its working for you guys. If you could list the parts that I would need to revert back to 4.5 from 3.85 that would be a big help. Looking at running slower head speed.
Trex 500 ESP(DFC) Ikon, Radix] [Goblin 700 CompBK, 4525, Ikon, Helix 695 ] [Rave ENV Nitro O.S 105-R,Ikon,Cyclone] Rave ENV Electric]Scorpion 4525,Ikon, Outrage, SAB [Goblin 500] Ikon Rails 516 ]Blade 180 CFX]Goblin 570 12S Xnova
Blade120 is offline        Reply With Quote Quick reply to this message
Old 04-10-2013, 07:32 AM   #2 (permalink)
You will have to slot the frames a little to get a good gear mesh. Here are the parts, I like it so far.
MOD 0.7 TAIL GEARING
Bearing Shaft: H60139A
Autorotation Gear: H60020A
Torque-Tube Gear: H60121
ranchhand is offline        Reply With Quote Quick reply to this message
Old 04-10-2013, 10:57 PM   #3 (permalink)
Thanks for the reply could you explain where the frames need to be slotted to get the mod to work? thanks again
Old 04-11-2013, 04:12 PM   #4 (permalink)
What you want to achieve is to move the complete tail boom case forward by about 0.5mm, to get a tighter meshing. So the 4 screw holes on the left the 4 for screw holes on the right plus oval holes for the tail boom positioning need to be elongated towards the front.
The exact amount of sloting the holes you need to determine by checkin the gearmesh. 0.5mm was fine with my 600 Pro. Slotting is definitely required I know from experience. Withouth the tail drive can fail under higher load - not nice
helicocrasher is offline        Reply With Quote Quick reply to this message
Old 04-11-2013, 04:16 PM   #5 (permalink)
The holes that the boom block bolts to. You can get away with drill them out to 4mm and then either slot were the tab from the boom block goes or trim some off of the boom block tab it's self.
I used those aluminum cup washers to help spread the clamping force out to cover the larger holes.
I just used a dremel and slotted the all the holes.
Old 04-12-2013, 11:14 AM   #6 (permalink)
Default Re: changing 3.85 to 4.5 ratio
Great info appreciate it, will give this a shot
Sent from my DROID RAZR using Tapatalk 2
Old 04-13-2013, 07:35 PM   #7 (permalink)
This will work too right? And this one is supposedly stronger.
http://shop.align.com.tw/product_inf...oducts_id=4911
Mike A. is offline        Reply With Quote Quick reply to this message
Old 04-13-2013, 09:52 PM   #8 (permalink)
Yes they will, I'm using them. They are really out of round though and I don't know how much stronger they really are, having such small teeth.
But you can be them from Align Trex Store, any order over $25 has free shipping, so if you get two sets or one of each, front and rear there's no shipping charge.
KDE is still working on a set also, but it's becoming quite a challenge trying to CNC them. Align is just thremo or injection molding them and that's why they run out so much.
Old 04-15-2013, 06:35 AM   #9 (permalink)
since I have changed to the original gear ratio I have so much more confidence in the heli. I can whip tight knife edge funnels feet off the ground with no fear! DO IT! I dont kno what align was thinking when gearing the tail
Trex 700L NEO / Mikado Logo 600SX Vbar 6.0/ Trex 470LM NEO, Oxy 2 CC Talon 25 NEO, 450 pro vbar 6.0pro/ Trex 700n DFC OS105HZR, Velocity50 Vbar 6.0pro -Oxy 5 NEO-/Trex 600efl PRO (Night Flyer) vbar/CC HV80 ......ALL VBAR CONTROL
Stevin is offline        Reply With Quote Quick reply to this message
Old 04-15-2013, 06:35 AM   #10 (permalink)
oh yea and im running
2150-2250
Old 04-15-2013, 07:57 AM   #11 (permalink)
How was the tail when running the suggested 2500 HS from the manual? I just bought one but didn't even think about the tail ratio when I was reading the specs before ordering. I'll probably just try all the settings from the manual and see how she fairs up. I'll also probably stand about 100' away from my 600 running 2500 hs
FBL aeolus 50-BeastX, RJX head, Novarossi .57, Edge 603/95 blades, GY701
130x- apparently a good one. Mine just works crash after crash
RaymondJ is offline        Reply With Quote Quick reply to this message
Old 04-15-2013, 08:27 AM   #12 (permalink)
Personally I've found 2300 to be a good speed where the tail is completely solid. Doing very fast and steep funnels the tail holds perfectly. I've never gone up to 2500.
Old 04-15-2013, 10:54 AM   #13 (permalink)
Cool, thats good to hear. Im going to be running 3300s so i would prefere more then 3 minutes of flight time
How is the tail in wind? Thats my other enemy is the wind here can make a good tail struggle to hold.
Old 04-15-2013, 11:19 AM   #14 (permalink)
With my 3300 packs I do 5min flights using about 70% of the capacity of my packs.
It's pretty common to have a decent wind blowing in my area, once I started flying at 2300 it's been solid. I flew it for a while at about 2100 and during hard funnels it would blow out.
Old 04-15-2013, 08:17 PM   #15 (permalink)
I can barely do a funnel, they are ovaled, ugly. But, I was nervous about having a tail blow out anyways. 75% of my flying is in the backyard, over a walnut orchard, not a lot of room to save it when something happens.
I used a set of edge 105's I had laying around and I confidently run 2000/2150/2300. No other mods. I'm just careful with take-offs and landings.
Logo 600 SE (HKIII 4035, Ice 4.02, Vbar 5.3, SX mods, Edge 690 & 105)
Gone but not Forgotten: MCPX, SR, Genius CP, 4G6, 4G3 , Trex 250, Trex 450 SE & Pro, 500 ESP, 700e V1 DFC, Protos Stretch, Logo 500 SE, 600EFL, Logo 600 3D .
phranticness is offline        Reply With Quote Quick reply to this message
Old 04-19-2013, 03:44 AM   #16 (permalink)
when I was running stock gearing I found 2400 to be the number that I had faith in. 2300 will do the job but if you have some packs that are getting tired be weary towards the end of the flight.
