Old 01-23-2017, 04:08 PM   #1 (permalink)
Default Trex 250 Pro DFC Tail Pitch Slider
There is a small screw in the blade grip hub, that secures the grips to the shaft, so the slider can move the blades.
The smallest hex driver I can find is a 1.5 which is too big. What do you use to tighten this screw??
Jim
jbewley is offline        Reply With Quote Quick reply to this message
Old 01-23-2017, 04:15 PM   #2 (permalink)
0.9mm, comes in the kit.
T-Rex 550E V2 Spartan VX1n, T-Rex 250 PRO DFC Spartan VX1n, Blade 130X. Futaba T8FG Super
Toocool4 is offline        Reply With Quote Quick reply to this message
Old 01-23-2017, 04:17 PM   #3 (permalink)
Originally Posted by Toocool4 View Post
1.3mm, comes in the kit.
Mine came with a hex and a screw driver, but the hex will not fit this screw for some reason.
Jim
Old 01-23-2017, 04:18 PM   #4 (permalink)
.9mm
Align sells a set for the 250 - a .9mm and a 1.3mm. The handles are so small that it was difficult to wrench on the heli. Thorp also makes that size which work much better.
Agile 5.5, Logo 550sx, X5, Goblin 500, Oxy 3, Trex 450proV2, 250DFC #309
nflanagin is online now        Reply With Quote Quick reply to this message
Old 01-23-2017, 04:26 PM   #5 (permalink)
Okay, i use this one
Old 01-23-2017, 04:41 PM   #6 (permalink)
Thank you all very much. Just ordered a set.
Jim
Old 01-23-2017, 04:49 PM   #7 (permalink)
Cool, it's good for the skids bolt as well.
Old 02-06-2017, 12:44 PM   #8 (permalink)
Another question concerning this slider.
I got the .09 wrench and tightened the set screw, using Loctite. However it still slips, causing me to lose the tail. It is only held in place by friction, not a flat spot or hole, like the main blades.
Has anyone else had this problem and if so, how did you fix it?
Jim
Old 02-06-2017, 02:16 PM   #9 (permalink)
Are you talking about the Tail Hub on the Tail Shaft. There is a hole at the end of the shaft - here's a picture for the tail replacement gears:
https://www.helidirect.com/helicopte...t-rex-250.html
If there's no hole, grind a flat spot in with a dremel.
Old 02-06-2017, 02:55 PM   #10 (permalink)
Thank you, as that explains it. There is no hole in mine. I wondered why there wasn't as that just makes sense.
Jim
Old 02-07-2017, 07:04 AM   #11 (permalink)
This is odd. I have done some checking and there are two rear drive set ups. One has no hole and one does.
Mine has a small allen screw. Can that be used with the hole or do you need a longer one?
Jim
