Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis
Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters
Old 04-02-2012, 01:27 PM   #1
nickyd
Default Who uses a separate BEC?
Since I swapped my HS65MG servos for MKS 95 servos I have noticed my Scorpion 45A ESC is really heating up. I have spikes on my servo bus voltage dropping down to 4.2V and had complete radio loss causing a crash.
I have been advised that I probably need a separate BEC so have ordered a Turnigy 5Ampone from Hobbyking. (http://www.hobbyking.com/hobbyking/s...for_Lipo_.html)
The internal scorpion bec is rated at 3Amps.
Any thoughts? How many of you are using a separate BEC and where do you mount it?
Or could my esc be on its way out? No flying for a while for me until the bec arrives anyway.
Nick
-Nick
Mini Titan E325 V1 FBL, SK720BE, T-Tube,Scorpion 2221-8, Ice Lite 50, CC 10amp BEC, MKS DS95 ,DS95i , Align 325mm Mains and Kbdd 61mm Tail Blades, . DX7 . Sport Flyer.
Nano Cpx (Inverted trainer)
nickyd is offline        Reply With Quote
Old 04-02-2012, 02:25 PM   #2
FR4-Pilot
What kind of BEC does your Scorpion 45A have - switching or linear?
SUCK LESS
FR4-Pilot is offline        Reply With Quote
Old 04-02-2012, 02:29 PM   #3
helicopter1
You should use a separate bec with that speed control. I think it only has a 2 amp linear bec and that speed control will run a lot cooler with a separate bec.http://www.hobbyking.com/hobbyking/s...Reduction.html This is the one I am using on my 450 and never had a problem.
helicopter1 is offline        Reply With Quote
Old 04-02-2012, 02:33 PM   #4
nickyd
i think it is :
15V LBEC (Linear Battery Eliminator Circuit) .will confirm later. thanks
-Nick
Old 04-02-2012, 02:41 PM   #5
helicopter1
I had the version 2 but version 3 has a 3 amp constant and 5 amp burst bec which theoretically should work.
Old 04-02-2012, 02:51 PM   #6
FR4-Pilot
Yes, stay away from linear BECs with anything over a 2S (7.4V) pack. With a 3S it has to drop 11.1V down to 5V and linear BECs burn that 6.1V off as heat - all of the time. Switching BECs don't do this and run much cooler.
SUCK LESS
Old 04-02-2012, 11:36 PM   #7
nickyd
So do you guys think the Bec ive ordered from Hobbyking(see post avove) will be powerful enough?
Nick
-Nick
Old 04-03-2012, 02:08 AM   #8
clicky
I have ds95s on my MT and was using BEC until last weekend. I swapped my Align's 35A ESC for HeliDirect one from HK - 45A version (YGE clone?) and dropped BEC... No problems even with tic/tocs or really hard stops...
BTW I think I love that ESC and I'll get another two! Aside of gov store and other things it was known for, I flew it in ambient temperature of 15-17C and at roughtly 70-80% of throttle doing lots of flips and rolls (and half piro flips and full piro flips) and when it landed I checked the temperature of ESC. It was COLD! Not gently warm as I expected (or on warmer/hotter side some bad ones were) - but COLD as ambient temperature! Definitively less than 36C (and probably around 20C!) as I could feel it being cold! LOL... Sorry - I just digressed!
One more detail: aside of MKS DS95s as feathering servos I have S9257 for tail (so still big and power hungry servo)...
clicky is offline        Reply With Quote
Old 04-03-2012, 04:32 AM   #9
nickyd
Hi Clicky,
Looks like a nice ESC you bought there. Unfortunately I already have my BEC on order, so I guess I will give it a go.
Where did you mount your BEC when you had one? I was thinking about piggybacking it on the ESC. Not the best idea for heat dissipation I guess, but neatly tucked away there (under the battery tray) if there's room.
If the BEC isnt up to it I will be ordering the same ESC as you.
I have looked up my Scorpion ESC and its internal BEC is rated at 6V/4amp 5 to 15V and is a linear BEC which may explain why it overheated with the DS95 servos respect to the HS65MG ones.
Thanks for the info.
Nick.
-Nick
Old 04-03-2012, 08:44 AM   #10
wbefield
Clicky, Is this the ESC you have?
http://www.hobbyking.com/hobbyking/s...ontroller.html
William
Synergy N5C, 130x, Mini Protos 6s
wbefield is offline        Reply With Quote
Old 04-03-2012, 01:01 PM   #11
clicky
Originally Posted by wbefield View Post
Yes!
Originally Posted by nickyd View Post
Hi Clicky,
I did same as you're suggesting: just piggybacked it to ESC.
Nick.
Now you're writing about it - I didn't have BEC on my MT until I got DS95s! It started overheating and cutting off. Fortunately it did it while I was on the ground setting it up and playing with servos.
Old 04-03-2012, 01:06 PM   #12
wbefield
I was going to order one to give it a try, but they are out of stock.
If it is in fact an exact YGE clone, then I should be able to use my YGE Program Card II with it. Anyone tried it? I have an authentic YGE 60A on my Protos and I love it. Top of the line ESC.
William
Old 04-03-2012, 01:15 PM   #13
clicky
Not sure if it is exact YGE clone, but I did use YGE original programming card (II I think) with no problems!
Also, people were pointing to that ESC's programming card as cheaper alternative to YGE programming card for original YGE ESCs So, it works in both directions!
If I didn't get my 120A and 100A YGEs for stretched and normal Protoses I would have bought one HeliDrive's 80A or 100A to test it, too!
Old 04-03-2012, 02:15 PM   #14
nickyd
Yes!
ahhh, I found out in the air no biggie, minor damage
-Nick
