Old 07-15-2012, 12:13 PM   #1
bladesr
Default Step G still not sure how to save properly
Should I leave Step G at one of the servos (with light on ) or at reference point (light off ) or it doesn't matter ??? thanks !
Trex450Pro BeastX
Trex550E HC3SX
Trex700E HC3SX
JR11X
bladesr is offline        Reply With Quote
Old 07-15-2012, 12:20 PM   #2
newbheliusr
Doesn't matter
Heli's I have:
Gaui X3 (Gaui Mini Vbar), Gaui X5(Mini Vbar), X7(Full size blue Vbar), Logo 400 (Gaui Mini Vbar)
I'm the not so newbheliusr as I have been here a while. But I like this name.
newbheliusr is online now        Reply With Quote
Old 07-15-2012, 12:35 PM   #3
sutty
+1, it doesn't matter. This having been said, there is a small advantage with moving on whilst one of the servo lights is on. This way you can definitely see that you are moving on whilst all the servos are in their adjusted positions. If you had missed one it would be obvious. Since all will be out, to some extent, when in the reference position, and all will move to the adjusted positions when you press the button to move on, it perhaps isn't so obvious if one has been missed. Or maybe it would still be obvious.
I assume you have a reason for asking? Are you having some trouble getting it to store the changes you make at G?
Cheers
Sutty
Regards, Sutty
BeltEXI, mCX, mSR, 4G3, FBL Trex250SE B, FBL Trex450Pro B,
FBL Trex550e VX1, FBL Trex600ESP B, Parkzone P51D, QRX350Pro
sutty is online now        Reply With Quote
Old 07-15-2012, 01:42 PM   #4
bladesr
To Sutty, no I don't think I have any problem in saving but just want to make sure since I am flying a 700 and try to be 100% sure for everything . I had seen many different opinion on this matter , I looked in the manual it didn't mention or the setups videos same thing. The more I read the forum the more I get worry , you know what I mean !! Regards.
Trex450Pro BeastX
Trex550E HC3SX
Trex700E HC3SX
JR11X
Old 07-15-2012, 02:04 PM   #5
sutty
If you have some worry, and I can undersand that for a 700, then simply look at J. When you go into J, if it starts at 0 on the blades, and your servo arms are square, or where you need them to be, like you set-up at G, then you know you did everything right, because J uses the same starting position as saved at G, in other words the elctronically adjusted centres.
You can also triple check by putting your radio at mid stick, in throttle hold, or with motor disconnected, and see if you get the same there as well. It should be at least very close, depending on the calibration of your radio.
The more you read the more you worry, well stop reading then, lol. Kidding of course, but if you have done a lot of reading then you will be better placed to understand all the potential issues, so you should worry less.
Good luck with the maiden.
Cheers
Sutty
Regards, Sutty
Old 07-15-2012, 02:50 PM   #6
bladesr
To Sutty ,
I think I did all the those steps you mentioned correctly It is for only the last part of the Step G I always thought each time I move a servo when in servo mode it is set at that position automatically , so I never think of when is the right position ( lights on / off) to leave Step G in order to save settings.
Regards
Anthony.
Trex450Pro BeastX
Trex550E HC3SX
Trex700E HC3SX
JR11X
