Like Tree1Likes
Closed Thread
Old 09-16-2015, 03:58 PM   #1 (permalink)
Default Single Vs. Dual layer winds
Im curious do single layer winds produce a higher winding factor than dual layer winds? I ask as the winds calculator reports it.
1BOHO is offline        Quick reply to this message
Old 09-16-2015, 06:42 PM   #2 (permalink)
Here is the result.
12N10P
Single Layer Kw = .96593
Dual layer Kw =.93301
Name:	1 Layer delta.png
ID:	609333   Click image for larger version
Name:	2 Layer Delta.png
Old 09-17-2015, 05:28 PM   #3 (permalink)
http://www.electrical4u.com/winding-...bution-factor/
RCM-BL700MX Single layer 2 strands of 16Ga. 3 turns wye. Will test.
Old 09-19-2015, 12:35 PM   #4 (permalink)
Hello,
More photos......
ID:	609784   Click image for larger version
Old 09-22-2015, 12:05 PM   #5 (permalink)
Using the drill press method in which mine is apprx. 2250rpm I measured 1.49Vrms on A B and C
So 2250rpm/(1.49Vrms x 1.414 x 0.95) = 1124kv
Old 09-22-2015, 10:24 PM   #6 (permalink)
Default Align 700MX 3turn double 16ga. SL WYE
Pulled a sustained unloaded wot run. Logging showed apprx 25,639 rpm @ 7.4 amps and 23.4 volts.KV estimation by log would work out to be 1095.
Name:	MX700 3Turn double 16ga. SL WYE  WOT IO RUN.jpg
Old 09-27-2015, 10:57 AM   #7 (permalink)
Since Ive already terminated laminated the wires with 7050 clearcast epoxy no need to pull it apart so I could wind the other six teeth the same way then terminate 3 more leads and parallel out side the motor. This way could I run 2 layer wye paralleling the the motor terminals AABBCC or delta if I pair 2 terminals from each single layer AB BC CA motor for DD??
A bit confusing if indeed a single layer A-b-C-a-B-c is simply one layer of winds on each tooth. I say this because if I wind the next 6 teeth the same way -a-B-c-A-b-C and parallel the leads that is a dual layer y wind according to the calculator AabBCcaABbcC but would still be a single layer according to some of the post Im reading, only one layer of coils on each tooth. Its confuses me because based on the calculators diagrams now matter how many winds I put on this it is still single layer which makes sense to me based on the pitch relationship between the magnet and individual coiled tooth - single layer vs the magnet and slot between two coiled teeth - dual layer. This certainly looks me the single tooth to magnet flux relationship might be better which leads to a better Kw.
It seems like no matter if you wind on two teeth 30 degrees apart versus one you will never achieve the better flux relationship because you are always still looking at the gap vs the teeth.
Im not making any definitive claims just looking for conversation and a better understanding either way.
Thanks for you time and thoughts
Name:	1 Layer delta.jpg
ID:	611111   Click image for larger version
Name:	single layer  -a-B-c-A-b-C.png
ID:	611112   Click image for larger version
Name:	2 Layer Delta.jpg
ID:	611113   Click image for larger version
Old 09-29-2015, 08:11 AM   #8 (permalink)
Hi,
Completed the second single layer WYE motor wound -a-B-c-A-b-C.
ID:	611557   Click image for larger version
Old 09-29-2015, 11:49 AM   #9 (permalink)
Originally Posted by 1BOHO View Post
... wound -a-B-c-A-b-c
Typo
-a-B-c-A-b-C
Vriendelijke groeten Ron
ron_van_sommeren is offline        Quick reply to this message
Old 09-29-2015, 11:59 AM   #10 (permalink)
Thats correct.
Thanks Ron. I fixed it.
Now all I need is to complete the FOC six phase controller .
TTYL
1BOHO
Old 09-29-2015, 12:26 PM   #11 (permalink)
FOC controller
sinusleistungssteller.de/en_High.html
→sinecurrent control
And Takao Shimizu is working on it
BLDC controller
Several other people have posted on FOC in the above long, excellent and active thread.
Old 09-29-2015, 10:48 PM   #12 (permalink)
Very interesting read,about the benefits of field commutation constant rotor speed mode for pilots.
Old 09-30-2015, 10:23 PM   #13 (permalink)
Hi,
Measuring the two separate WYE motors rm returned 10.3 milIiohms for motor 1 and 10.7 for motor 2
ID:	611848   Click image for larger version
Old 10-02-2015, 09:49 PM   #14 (permalink)
Looks like if I want to retain the .96 Kw of a single layer but in a parallel y scheme it should be this with each half of the stator only 3 teeth wound.
Old 10-08-2015, 05:13 PM   #15 (permalink)
Single Layer 13 ga. 4 turn parallel wye.
ID:	613133   Click image for larger version
Name:	SL 4 Turn 13 Ga.  YY.jpg
Old 10-09-2015, 10:41 AM   #16 (permalink)
Motor 1
Motor 2
At 15 degrees timing both wye motors Kv logged apprx. 2320kv
T600 4030 4 turn Single Layer 13 ga. parallel wye.
12N8P Kw .86
Name:	T600 13 ga 4 turn parallel wye motor 1 idle current log.jpg
ID:	613235   Click image for larger version
Name:	T600 13 ga 4 turn parallel wye motor 2 idle current log.jpg
ID:	613236   Click image for larger version
Name:	t600 4turn.jpg
Old 10-13-2015, 04:08 PM   #17 (permalink)
12N10P 5 turns SL 13 ga. A-b-C-/a-B-c- terminated DD
Edit.....
Ill leave it with 6 terminals for 2 controller and or 6 phase test.
ID:	614451   Click image for larger version
Old 10-27-2015, 06:02 PM   #18 (permalink)
A bit off topic for this thread but here is the Triebflügel drive in real rc and animation.Can you build it?
I wanted to share it so I put it here in my thread where an interesting off topic might be allowed.
http://www.seeop.com/development/spi...380&modal=true
Enjoy
We're all still eating anyway....
Old 11-01-2015, 02:54 PM   #19 (permalink)
Default Align 700MX 6+5 YY 1.32mm ( 13ga.)
6+5 YY 1.32mm (13ga.) dual layer. 58% copper increase.
I will post constants as they are recorded.
Scoped bemf of two phases.
ID:	617196   Click image for larger version
ID:	617200   Click image for larger version
Old 02-06-2016, 11:44 AM   #20 (permalink)
Photos of the most recent single layer wind a YY wind. 6 Turns of 13 Ga.
ID:	633858   Click image for larger version
ID:	633859   Click image for larger version
ID:	633860   Click image for larger version
Closed Thread
