Old 05-26-2013, 01:43 PM   #41 (permalink)
Originally Posted by Daddy View Post
Yes, mine did. Don't bother to connect, just click "upgrade" in John's software.
Ya I tried that first. It was a no go. I can't even get it to power up now so I'm thinking I just got a bad one.
LM321 is offline        Reply With Quote Quick reply to this message
Old 05-26-2013, 01:43 PM   #42 (permalink)
+1, that's how I did it too.
Crash22 is offline        Reply With Quote Quick reply to this message
Old 05-26-2013, 04:09 PM   #43 (permalink)
This same scenerio has happened quite a few times and with cross flashing CX unit. Keep trying to flash it as it eventually seems to take for most people.
Look here
Sigma, MCX, MSR, BOL, B400
BSR, EXI 450 Pro FBL, mCPX
Align 500ESP FBL
AXN FPV
Daddy is offline        Reply With Quote Quick reply to this message
Old 05-26-2013, 05:20 PM   #44 (permalink)
Worked for me like that too.
Swift 16 - Futaba 7C 2.4 -
Tarot 450 FBL SK 720
Co Pilot II - Previous rides: CopterX 450 HP Black Hawk 450 Esky Esmart 600
Locitur is offline        Reply With Quote Quick reply to this message
Old 05-26-2013, 07:19 PM   #45 (permalink)
The dynams seem to stay partially powered wwhen.connected to the USB. Connect like normal and when.u go to.flash and go to unplug heli power also unplug USB wire from.the dynamic. Hold in button. Replug heli wait for flashing red then plug USB back into dynam and update. If u unplug the USB it won't work.
paedbo is offline        Reply With Quote Quick reply to this message
Old 05-26-2013, 09:38 PM   #46 (permalink)
Well... I'm getting closer I guess. Finally got some leds to respond and was able to flash, but now when I restart it, I get the flashing blue led. Receiver and leads are fine because the ZYX re-initializes just fine. I'll keep banging away at it.
Old 05-26-2013, 10:46 PM   #47 (permalink)
Good to hear! Can you connect to pc now? Check all the setup's. Blue flashing is initialization error btw.
Align 500ESP FBL
AXN FPV
Old 05-26-2013, 11:19 PM   #48 (permalink)
Ya i can connect to pc. Still get the flashing blue light half the time. Also servos are moving on their own. Not jittering but full throw about every second. Also appears that i cant get cyclic roll and pitch to work at the same time. One time i restart and i only have roll. Next time only pitch. I'll give it a rest and come back later. Im thinking i might have to cut my losses. For 25 bucks it was worth a shot.
Old 05-27-2013, 05:33 AM   #49 (permalink)
did you flash the correct zyx-s firmware?
Old 05-27-2013, 02:23 PM   #50 (permalink)
I've tried zyx-s versions 3.5, 4.01 and 4.02. I don't have a copy of 4.0. All versions were for the zyx-s though, and I get the same results with all three. When I first turn it on, some times it initializes some times I get the flashing blue light. If I get the flashing blue light I can hold the set button for a few seconds and it will initialize. When it first starts, everything seems fine pitch, roll and yaw in the right directions along with the compensation. After about a minute, the swash will pitch either forward or back begin cycling forward and backward. All three servos move together and go full deflection as if I were moving the cyclic stick up and down. It moves at a rate of about once every two seconds and then some times speeds up to about once a second.
Old 05-27-2013, 05:30 PM   #51 (permalink)
sounds faulty send it back for a replacement.
Old 05-28-2013, 11:44 PM   #52 (permalink)
My first time working on this. I managed to connect and bind it...seemingly...Anyway I can transmit changes to the unit, however, I can't get it to update the firmware. I get a timeout error. Any help will be appreciated.
Thanks!
balbs is offline        Reply With Quote Quick reply to this message
Old 05-29-2013, 01:04 AM   #53 (permalink)
I found these instructions to update the firmware. Will try again later.
http://www.rcgroups.com/forums/showt...512179&page=87
Old 05-30-2013, 05:52 PM   #54 (permalink)
CRAP!!! So I finally got it going...seemingly...I see a progress bar going and packets sending. After a few seconds, I get an error and the update stopped. Now the lights on the controller won't turn on at all. No diagnostic lights. The DSM2 satellite lights up and seem to bind, but I get no lights from the controller. Did I just turn this into a little brick?! Please help!
Old 05-30-2013, 08:47 PM   #55 (permalink)
Use these instructions to do the firmware update again
http://www.rcgroups.com/forums/showp...postcount=7608
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote Quick reply to this message
Old 05-30-2013, 09:54 PM   #56 (permalink)
Without doing step 4, as it wont connect if the gyro wont initialize.
Gaui X2 FES ZYX, Gaui X3 MB, Gaui X4 II VBar, Gaui X5 FES MB
250 DFC ZYX, 450 DFC Sport MB, ALZRC 450L Pro VBar, Devil 450 FAST VCTRC FBL
500E DFC Pro VBar, 500E SDC ZYX-S
KDS 550 VBar, 550E DHPS VBar, 550E DFC Pro VBar, 700E DFC HV iKon
beenflying is offline        Reply With Quote Quick reply to this message
Old 05-30-2013, 10:29 PM   #57 (permalink)
What's "John's app?. I just have the Tarot app. Got a link to it?
Old 05-30-2013, 10:33 PM   #58 (permalink)
John's App: http://fbl.net.nz/
Old 05-30-2013, 10:42 PM   #59 (permalink)
Thanks!
Old 05-31-2013, 01:04 AM   #60 (permalink)
Thanks again! I managed to wake it up! However, the blue light won't stop flashing after the test phase. I was trying to keep it as still as possible but the blue won't go steady.
