NX4 Discussion and support of the Gaui NX4 Nitro Helicopter |
09-11-2016, 08:34 AM | #1 (permalink) |
1100mah life pack
How many flights can I do with 1100 mha life pack or should I not fly with a pack this small?
Nankinhobby.com Field Rep Compass Support TDR, Minicoptor Diabolo 550, Compass Atom 500, Compass Atom 6HV, Compass Warp 360, Gaui NX4, Check out my YouTube channel: thedaveyht3 |
09-11-2016, 12:12 PM | #2 (permalink) |
1100mah life pack
If it helps, I fly with a pulse 1350 (2s lipo) and get at least 5-6 flights before 3.8v per cell. Servos make a big difference. Used to only get 4 flights with a slow throttle servo that couldn't keep up with the gov.
09-12-2016, 09:12 AM | #3 (permalink) |
What servos you have matters. I had 3 omg brushless cyclics, a futaba brushless tail and jr throttle, and i ran a nanotech 850mah 2s lipo (not life), and I would get four 6minute flights. But I usually wouldn't even unplug the heli in between the flights.
09-12-2016, 03:06 PM | #4 (permalink) |
I have no problem to have about 4 or 5 flight from 1450 LiFe battery with reserve.
1 flight is about 8 minutes. Cyclic: 2x DS515/1x Futaba BLS173 (next ones will follow) Tail: KST BLS505X Throttle: DS510
Gasserheli Morphis, Hanson 300, Spirit FBL; Logo 600SX, HC-3sX; T-Rex 470LP; Miniprotos, Helibug 600, HWC700PUH, HWC 600, T-Rex 600 GT15HZ600 conversion, T-Rex 600 GoEngine 56, T-Tex 600N; Last edited by SlezY83; 09-12-2016 at 03:07 PM.. Reason: Added fly time |
07-14-2017, 08:09 AM | #5 (permalink) |
Battery for LIFE and Rx
I have a 1300 mah LIFE I was thinking of using in mine. I have a NX4 combination kit and the G10 gas motor. My concern is battery life if one battery supplies both power for flight pack and CDI.
But...... I fly gas airplanes and there I use separate packs for both. I would assume I should do the same here so what size packs would everyone recommend for this setup? Can the RC heli get 4 to 5 10 minutes flights on a normal battery pack like a NMH and use a LIFE pack on the CDI unit? Just thinking out loud and wondering what you all are doing and seeing. |
07-31-2017, 07:45 PM | #6 (permalink) |
Well reading what you guys run, I may have overdone it a bit. I'm using a 2550mah 2S lipo Pulse receiver pack. It has 6 (or maybe 7?) 6 minute flights on it and the cells are each at ~3.89
08-07-2017, 01:48 PM | #8 (permalink) |
it sure does. I can't wait to fly it again. (thanks for your help )
08-28-2017, 01:00 PM | #9 (permalink) |
;wow i can only get 2 flights on mine before i am having to recharge...what setups are you guys using for servos? i have bk ds5001hv cyclics and ds-7005hv tail servo and the gaui gs 303 on throttle. running beast x and tm1000 telemetry module and gens ace 2200mah 45c pack and after 2 6:30 flights the pack need recharge and putting back 1750mah in the pack.....seems im using alot of mah per flight in comparison to others
09-10-2017, 04:07 PM | #10 (permalink) |
My NX 4 Experience and battery life
I fly the Hyperion LiFe 1450 mAh flight pack on my NX4 (gas engine).
In 3/4 tank of fuel (mainly hovering) I find that I am consuming about 450 mah of power. I am guessing I may get 2 tanks to 1 flight pack. Guess I am buying some more flight packs. |
