Old 02-09-2017, 03:47 PM   #1 (permalink)
Default 450 headspeed
Running 3s what's ideal headspeed gonna setup governor in talon 35.
Flying 3d is offline        Reply With Quote Quick reply to this message
Old 02-09-2017, 03:58 PM   #2 (permalink)
That depends on the model, motor, esc and gearing. I try to gear my helis to get my desired headspeed at 75% flat throttle. Things seem to run cool and bogging is kept to a minimum. That's with YGE/YEP esc's in gov store mode.
Mini Protos 6s stretch/XK K110/Trex 450sport v2 fbl/Rochobby Nemesis NXT/RareBear funfighter620mm
~Problem Child~
learnedthehardway is offline        Reply With Quote Quick reply to this message
Old 02-09-2017, 04:16 PM   #3 (permalink)
450l dominator with the stock 3s motor and 11t.
Old 02-09-2017, 04:16 PM   #4 (permalink)
And talon 35 esc
Old 02-09-2017, 06:09 PM   #5 (permalink)
Enter all the info for your Heli here and it will give you a range that you can run with your current setup. If you want more or less headspeed you can figure out what pinion to get. There's a fairly wide range ppl run. Some want lower headspeed/longer run time while others want high headspeed/short flights
When I had a 450pro I think I ran it around 3100
http://calc.kfmconsulting.se
CrashNburn420 is offline        Reply With Quote Quick reply to this message
Old 02-09-2017, 06:10 PM   #6 (permalink)
What head speed you looking for? Looking at Castle link I'd be installing a 12T and run 2800 - 3000
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4,
X5 stretch 220 Flame Emax Bullet Force V2 VTX
bad007 is offline        Reply With Quote Quick reply to this message
Old 02-09-2017, 06:28 PM   #7 (permalink)
It depends on how you want to fly. I have run from 2800-3600.
Team Synergy
Dylan Hudock is offline        Reply With Quote Quick reply to this message
Old 02-09-2017, 06:52 PM   #8 (permalink)
I looked at his stats, I don't think he is going to want 3600 yet,
I like 3300, no less.
Old 02-09-2017, 06:57 PM   #9 (permalink)
Understandable. There is a range where the heli will fly better, in regards to cyclic authority and tail authority. You can then tune it in the fbl to the flight characteristics you would like. Having it geared correctly for your headspeed does make a big difference in efficiency, running temps, and flights times.
Team Synergy
Old 02-09-2017, 07:57 PM   #10 (permalink)
Thanks for all info I set it up went 2650 2850 3100. Do I have to go through the beastx again or am I able to test fly.
Old 02-10-2017, 06:11 AM   #11 (permalink)
Fly! You just need to fine tune the cyclic gain.
What's the motor KV? 3200, 1:11 ratio?
The only thing is Control Style B is best set to TX mode and then use the rates and expo in the TX to your feel.
Old 02-10-2017, 04:39 PM   #12 (permalink)
I think that is a good range. I aim for about 2800 on a 360mm blade heli. That has plenty of power for sport and aerobatics.
Oxy 2, Gaui X3 #1, Protos 380, Gaui X5, Synergy 766, Specter 700
Oxy 2/X3/Protos 380/X5/766/Specter 700 Consecutive Successful Flights (Current) = 32/16/12/145/7/50
Consecutive Successful Flights (Max) = 145
macdad is offline        Reply With Quote Quick reply to this message
Old 02-10-2017, 11:02 PM   #13 (permalink)
Yes it's 3200. Ratio what ya mean by that still working on terminology. It's actually a 12t after all counted 6 times. The cyclic gain in beastx correct.
Old 02-11-2017, 06:36 AM   #14 (permalink)
The ratio that he is referring to is the pinion to main gear. Divide your total teeth on the main gear by the teeth on your pinion.
Old 02-11-2017, 07:28 AM   #15 (permalink)
Thought so, no way with 11 tooth pinion.
How are you setting this up lf you don't didn't the ratio?
The cyclic gain, pot 1 on the BX will need fine turned. Try in all 3 modes. Too low drift and sloppy feeling, too high cyclic rocking, feeling locked in and stable just right.
