Old 07-15-2012, 08:13 AM   #1
varacer
Default need help picking which rx
Ok the radio is the 8fg heli is a 700n with vbar. Trying to figure out which rx to use with a gov which the gain has to be on ch7 or 8.
So does that mean the 3 ch sbus rx is out? If I get the 8ch sbus and use the sbus for the vbar can I use the open channels that are sent out over the sbus for something else?
varacer is offline        Reply With Quote
Old 07-16-2012, 02:24 PM   #2
cbane
I'm not familiar with Vbar, is it possible to customize the channel ordering (both the Futaba CGY-750 and the BeastX can do it)? If it's possible, you can move the governor output to channel 1-3, move whatever was already on that channel to the channel the governor was on, and then set up the Vbar to match.
Another option would be to use the built-in governor in the Vbar, if it works with nitro helis.
Either of these would let you use the R6203SB.
cbane is offline        Reply With Quote
Old 07-16-2012, 04:12 PM   #3
dkpodder
Yes, it is possible, no problem.
Yes it does, very well in fact.
dkpodder is offline        Reply With Quote
