Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters
E-Sky Helicopters E-Sky Line - Help each other out!!
Old 10-23-2008, 01:25 AM   #1
psilo
Default Align Shaft with CopterX tail?
OK, being lazy now, tried searching but too many results :o
Does the trex 450 (or copterx) tail fit as a drop in replacement for the belt cp boom? I am picking up a CopterX head and tail and UGT-05 swash when I return to UK next week and need a new boom, as I have the CopterX I would rather just buy the Align booms and that way I can keep one set of spares.
Gerd
T-Rex 500 µBeast, 450 Pro (soon to be µBeast) & a Compass 6HV
And a P51D plank......SSssssshhhhhhh!
BMFA & RCHA Member
[B][COLOR="Blue"]
psilo is offline        Reply With Quote
Old 10-24-2008, 12:12 PM   #2
Ian 777
Yo Gerd
On my tail box the align tail pinion is slightly too wide and side loads the bearings if you dont shave a tad off the pinion. I still use them but i use a needle file to remove the excess.
On the UGT swash you need to file down the arms that the balls are mounted on or they foul the ball links on full deflection and can force the link off the ball. It is also larger diameter than the Esky so it affects the alignment of the links and slightly gears down the pitch range..... I think ......
If you havn't bought it yet. Then the mini titan E325 upgrade swash supplied by Blink and Sportsmoto is a better option though it's silver not blue, but that looks cool with the other silver bits on the heli.
Trex 500 ESP
Phoenix Flasher 450
Frankenbelt
Ian 777 is offline        Reply With Quote
Old 10-25-2008, 06:40 AM   #3
another_finn
I use a Microheli T-Rex tail with an Esky CF boom. Drop-in fit, no problems. If you want to use an Align spec boom, just get a matching belt and it should work fine.
Mika
T-Rex 600NP, T-Rex 500 ESP, HDX500 SE V2, HDX450 SE V3, T-Rex/Outrage SE V2, EXI450, T-Rex 250, CopterX/Guru-Z hybrid, HBFP separates, Lama V4, 2 x Walkera 4#3B
another_finn is offline        Reply With Quote
