Old 10-23-2008, 01:23 PM   #1
huskynox
Default 8717 on 8v Failure Poll
Just out of curiosity I wanted to see how many people running on 8v have actually had a failure.
I put put this poll in JR Radios section. Here's the link:
http://www.helifreak.com/showthread.php?t=100110
Will James said it was cool to muli-post and link to the poll
500CF - 3650's, 3500G, Spartan, Stock ESC, Stock Motor, TP 6s Pro Power 2700mAh
PROTOS - 3650's, 3500G, Spartan, Scorpion 3026-880, ICE Lite 100, TP 6s Pro Power 2700mAh
600E - 8717's, 8900G, Spartan, Scorpion 4025-890, CC HV85, TP Pro Power 8s 3850mAh
Kasama Srimok - 8717HV's, 8900G, AR7100R, Spartan, YS 91SR, Hatori SB19
huskynox is offline        Reply With Quote
Old 11-05-2009, 03:02 PM   #2
huskynox
Just wanted to bump this thread since it's been a while. There's probably a lot more long time users of 8717's on 8 volts now.
Please participate only if YOU personally are running the 8717's on 8 volts.
Also, if anyone is running 8717HV's and has had a failure please post and tell how it happened.
Old 11-05-2009, 04:17 PM   #3
SwePilot
What is so fantastic with 8volt then, is it worth to put cyclic at risk?
600 ESP, DS620 cyclic, Spartan 760 + JR8900
CC ICE 100, Hacker A40-10L 8 Pole Turbine Motor.
600 MI 24 Hind Scale with 5 main rotor blades
SwePilot is offline        Reply With Quote
Old 11-05-2009, 07:26 PM   #4
Sonny
Sofar 1 1/2 going on two with 8717s at 8v. No problems yet. At least with that part of the system anyway....
Sonny
http://www.myspace.com/scottsonnyyoung
Sonny is offline        Reply With Quote
Old 11-07-2009, 10:38 PM   #5
Woody67
Arrow
I have been running 8717's on 8 volts (Trex 600N) *using a Fromenco Kiwi pass through" for over a year now, with no issues....
They sure are FAST at that voltage - love them..!!!!
Woody67 is offline        Reply With Quote
Old 11-12-2009, 08:33 AM   #6
snjbird
I made the switch to 8V on my 600 about 9 months ago, so far so good, running off the lipo to the 921 and then the spektrum VR for gov and gyro!
snjbird is offline        Reply With Quote
Old 11-12-2009, 08:43 PM   #7
xStatiCa
Might be interesting to have another poll for failures on less than 8v to compare how many votes with how many failures there are on both configurations. Seems like just having numbers on one setup won't really give much to compare with. It could just be the normal failure rate of the servos at any voltage.
xStatiCa is offline        Reply With Quote
