| 250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
what batteries we all looking to run..?
i have two 730 mah prolites sitting around doing nothing. they only wiegh around 30 grams! not sure how well they will hold up 3D, but its worth the try. looking at the specs we see now Align is recommending 850 3s. the OUTRAGE 800mah packs come in at 65 grams! anyone have any light cheap packs out there they will use? |
I'll probably use Revolectrix 3S 750 or 950 packs.
http://www.fmadirect.com/Detail.htm?...206§ion=69 http://www.fmadirect.com/Detail.htm?...208§ion=69
Team Synergy |
I'm planning on using the 3s Outrage and some of these cheap Zippys.
1) http://www.hobbycity.com/hobbycity/s...idProduct=6784 OR 2) http://www.hobbycity.com/hobbycity/s...idProduct=7481 |
i've been using gaui 800 mAh batteries and they have served me well. i get 4:30 on my gaui 200, and after 160 or so flights, only one went bad out of four. i wish outrage made a 800 mAh battery that was shorter. i was very impressed with my outrage 6S 2500 mAh i have for my hurricane 425. that is the best battery i have used to date.
ive just purchased 4 outrage 3s 2200 packs for my 450 to replace my thunder power and flight power packs. after a few flights i can really tell these lipos have great power. now i need a better motor!
i may give zippys a try. cheap, heard good things, and if they go bad oh well the price cant be beat |
#6 |
all of these packs you guys are listing are twice the weight as the TP prolites..
any other lite packs out there? TP prolite 910mah might be the ticket |
#7 |
I like the look of those $10 zippys. I can buy 5 and fly all day.
#8 |
#9 |
i have a feeling that zippy's are going to be in short supply very soon. all these new 200's coming out. get em while they last, boys.
#10 | |
Outrage R/C 3s 800 65g Not quite half as light. Plus, the TP Pro-Lites max continuous discharge is 14C to the Outrage's 25C.
#$^**&^$#^*(()*^%$#@@#% To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#11 |
so much current does it use?
450 GF Blinged 65hb/401/9650-DX7 500 CF 5245/401/9257 -DX7. MH150 CX2 |
#12 |
So... One of the Zippys is 36mm wide... Does anyone else think that may be too wide? On the other hand, the other one looks too tall at 23.5mm... I wonder if that'll fit too. Can anyone guestimate from the current Trex 250 pictures what will fit?
#13 | |
#14 |
Kinda leaning towards that one... The problem with HC is getting them in stock now...
#15 |
how about these lipos? i hear the zippy rhino version is better than their regular version. it's 100 less mah but i don't think flight time will be much less.
http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack |
#16 |
Hi there
I was under the impression Align was releasing a new pack for the 250 11.1V(3S1P)850mAh - 55x30x22mm - 68g http://www.align.com.tw/shop/product...oducts_id=2550 So if you looking at packs with similar sizes and weight you should be pretty safe! Fly safe Ken |
