| 250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I'm planning on getting some lipos and connectors in advance and noticed that the RCE-BL15X ESC has the JST connector pre-soldered for the lipo. Are those connectors strong enough for the amount of amps going through the system? Do they need to be deans (or mini-deans)?
I've had a number of bad experience with this type of connector (connector melting, shorting, etc.) on larger brushless system. Not sure what type of amps go through these little guys. |
Just chop them off and go with Deans. That is what I plan on doing.
This website rates JST connectors at a max of 5 amps.
#4 | |
wonder why align would put such a low amp connector? maybe they are trying to cut cost or overall system draws very low voltage? |
The Gaui 200 runs just fine on the JSTs even with a modded motor.
The dont get hot at all and with over 400 flights on 4 gaui batts and 2 gaui 200s Ive had no issues. |
#6 |
go micro deans.. i think they are rated up to 12 amps. i dont think this little guy will pull more than 10 amps on the stock setup.
