| 250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
#81 | |
MCPX V2 Stock, BL MCPX HP05 HP03, DX6i TREX450 SE V2 DFC, 35X, 2221-8 12T , BEASTX, HS65MG, HSG5084MG, R617FS, 7C Team Taco Pilot |
#82 | |
#83 |
so everything that was assembled had locktite. did you check over all the parts to make sure?
Dave Ketelhut To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Team Compass USA Gens Ace Prostarhobby.com |
#84 |
My tail grips needed a bit more loctite, looked like they had something in there but barely. Otherwise all other parts were ok.
#85 |
Dont want to hijack the thread but here is my electronics placement.........I recon its the most challenging bit of the build so it could help others....
Kenny.c |
#86 |
Very nicely done! Thanks for sharing.
I wish those Futaba FASST receivers has horizontal pins. It would make things a lot easier. |
#87 |
kenny, how is the c.o.g.?
#88 |
Thanks kenny.c
#89 |
Looks like I can see a servo connector laying horizontally through one of the wholes cut in the frame, so it's probably a 6100E. I almost always use 6100E's because like Steph said, it really does making the wiring less of a hassle.
#$^**&^$#^*(()*^%$#@@#% To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#90 |
what a nice build !
Never Underestimate The Power Of Stupid People In Large Groups |
#91 |
Hi
Thanks for the comments guys.......balance wise with my 83g lipo its perfect! Im not sure how you could move the weight around if the pack was much lighter to be honest....? Below is the heli hanging off the flybar using locking wire......its pretty well balanced Im using a 6100e reciever......just because thats what I had spare. But ive seen this picture using a 6100....it has the effect of moving the weight forward if your using a lighter lipo... ![]() Fly safe Ken |
#92 |
hi
can somebody tell me if the HS 45 fits in the frame ???? THX |
#93 |
maybe a 200 with the motor mounted up higher. hmmmm seems like all the weight on the bottom would make it harder to flip, which is a problem with these little guys. V2/250 ?
#94 |
i got a quick question. i was lookin at the manual posted, and it says you need CA glue. now instead of CA glue can you use superglue instead or is CA different kind of glue than superglue?
it's not in the kit is it? |
#95 |
ca=superglue
#96 |
that's what i thought, but wanted to make sure it wasn't something totally different from superglue
#97 |
CA = Cyanoacrylate so if it shows that on the label then its CA.
There are different viscocitys of CA, thin, medium, and thick. Superglue is usually medium or thick. |
#98 |
one question guys.
I see the main head is already assembled from factory, all guys says that we have to check if the screws have thread lock, but do you recomend to disassemble all and restart to build from 0? or if it's everything ok how can I check if one screw has thread lock without being removed? ![]() ![]() |
#99 |
You can't; Just take one screw out, clean it, Put some LT on it, and put it back in. Will take no more then 15 minuts, and gives you some familiarity with it. Just don't overtork it, no need to. Best of luck!
T-Rex 250 super combo T-Rex 450 PRO - I love this little guy! T-Rex 450 SE V2 - Sk360 in Airwolf fuselage T-Rex 500 Blinged to the extreme - Sk360 - Gy401/S9257 - 5045MGs T-Rex 600 LE - KDE everything, waiting on RL53 Raptor 50 eCCPM 140- QuickUk everything - G7703D/S9254 - S9252s - RedLine53 |
#100 |
