Old 11-05-2008, 09:41 AM   #1
skigolfmike
Default Align 50 Hyper Bearings
Does the Align 50 Hyper use the same bearings as the OS 50 Hyper. Since it's a copy, I'm assuming it should.
Since I'll have to replace the bearings in the motor eventually anyway, what are the best bearings for this motor?
TRex700N, TRex600NP
Logo 400 VBar, Furion 450, Blade 400
Gooie 200 (2), CX2, mSR
AMA# 3066
skigolfmike is offline        Reply With Quote
Old 11-05-2008, 11:29 AM   #2
nitro burner
Yes i think the bearing are the same, I just replaced the bearing in one of my OS 50 Hyper's try RC-bearing .com very nice bearing at a good price.
T-Rex 450 Pro FBL ZYX,T-Rex 700 Nitro FBL BEASTX,T-Rex 700 Nitro FBL BEASTX
Spektrum DX8,AMA#849731
nitro burner is offline        Reply With Quote
Old 11-05-2008, 02:58 PM   #3
skigolfmike
How about these?
TRex700N, TRex600NP
AMA# 3066
Old 11-05-2008, 04:22 PM   #4
BarracudaHockey
http://www.rc-bearings.com
Same as boca only a lot less expensive. Yes its the same rear bearing as the OS and YS 50s
Andy
AMA 77227
Jacksonville FL
http://www.jaxrc.com
BarracudaHockey is offline        Reply With Quote
Old 11-05-2008, 10:01 PM   #5
TheBum
There's some debate about using ceramic bearings in engines. The balls have the potential to shatter, which would definitely not be good for the engine. Stainless steel would be safer. Ceramics are fine for shaft bearings, etc.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is online now        Reply With Quote
Old 11-10-2008, 11:47 PM   #6
RC-Bearings
I have sold hundreds of ceramic bearing sets. I have sold many more stainless steel sets!
RC-Bearings is offline        Reply With Quote
Old 11-11-2008, 12:58 AM   #7
Steelie
My ceramics are working just great. No issues. Was a bit hesitant at first after reading some posts in the forums. I had to use one finally because I had no other at the time of the last rebuild. I'd use another... no problem.
Groucho Marx: "Those are my principles. If you don't like them I have others."
Steelie is offline        Reply With Quote
Old 11-11-2008, 01:02 AM   #8
lovespicyfood
For the people that used ceramic, is there any noticeable difference in performance? Just wondering...THANKS!
lovespicyfood is offline        Reply With Quote
Old 11-11-2008, 07:34 PM   #9
wmartin
I recently (within the past two weeks) replaced the stock bearings in my TT53 with a set of ceramics with stainless steel rings from rc-bearings.com. Although I've only managed a couple of flights with the new bearings, I gotta say my engine runs noticeably smoother and quieter (sure, the original bearings were worn). I haven't had a lot of time with them yet, but so far I'd say it was an excellent upgrade for only $32. Coincidentally, the TT53 and the O.S./Align share the same bearing sets according to rc-bearings.com.
wmartin is offline        Reply With Quote
Old 11-12-2008, 05:01 PM   #10
BarracudaHockey
The cheap ones run just as well, and last just as long as the ceramics.
Andy
AMA 77227
Jacksonville FL
Old 11-12-2008, 05:05 PM   #11
MrCLoWnY
Can you guys suggest a good time to check and change the bearings? Or is it one of those things, where it just goes out with no notice?
T-Rex 600 NSP | YS 50 w/MP5 SB | Futaba GY611 w/BLS251 & BLS451 x4 | Flight Log: 5 gallons! & 1.5 Crash | ROTORTECH QUALITY SUX!
T-Rex 450 SE V2 | Scorpion 2221-8 / 60 AMP ESC V2 | Align GP750/S9257 | HiTEC 65MG @ 6 volts | KBDD Tail Blade | ROTORTECH QUALITY SUX!
T-Rex 250 | DS410 x3 | GP750 Gyro w/ 3500G | 205D CF | DS420SUCKS!!! |
MrCLoWnY is offline        Reply With Quote
Old 11-12-2008, 05:21 PM   #12
BarracudaHockey
You will hear it
Andy
AMA 77227
Jacksonville FL
Old 11-12-2008, 06:03 PM   #13
TheBum
I always wondered: can you hear it at idle or only upon spool up. I swapped out my bearings preemptively while I had the engine out for other purposes.
HeliFreak Support
Old 11-12-2008, 08:25 PM   #14
HydroJoe
I heard mine go bad at idle. One day it just sounded a little off. I was on my 10th gallon before hearing it. It diddnt even sound all that bad. Ive heard descriptions of engines sounding like coins rattling in a can. Upon taking it apart, the bearings proved to be bad.
T-Rex 600 Nitro Super Pro
T-Rex 450 SE V2 on 4s
PZ 27C Stryker (yea, it's a plank)
HydroJoe is offline        Reply With Quote
Old 11-13-2008, 12:42 AM   #15
devious17
The rear bearing on my align 50 has lateral movement in it and I am told it will influence the 'timing' of the engine ad the side effect is reduced torque even though RPM is maintained .
It had about 5 gallon though the engine but that was the result of flying on clay field which the dust mixed with nitro become liquid sand paper.
So long xCell! Hello GAUI Heli's!!!
devious17 is offline        Reply With Quote
Old 11-13-2008, 09:23 AM   #16
BarracudaHockey
If you want to check the bearings, at idle put the tip of a plastic handled screw driver (I actually use a 6mm ball driver) on the backplate and put your ear on the handle.
Andy
AMA 77227
Jacksonville FL
Old 11-13-2008, 09:57 AM   #17
MrCLoWnY
nice, like playing doctor? hehe
Old 11-13-2008, 10:40 AM   #18
skigolfmike
I have been told these engines have a tendency to eat the rear bearing due to a very slight misalignment in the case. I wonder if there is a self aligning bearing that would work for this motor that would fix that. The kart engine builders have been using those bearings forever, especially if they have an engine they can't get the crank perfectly straight on.
TRex700N, TRex600NP
AMA# 3066
Old 11-13-2008, 10:42 AM   #19
MrCLoWnY
I'm a total newb so I didn't even now there was a bearing in the motor... Only bearing I noticed was on the shaft of the motor.. the one way bearing.. So this bearing is in the motor itself?
Old 11-13-2008, 10:52 AM   #20
SadSack
its at the back here. Can see edge of bearing
SadSack is offline        Reply With Quote
