Go Back   HeliFreak > R/C Electronics Support > Spartan RC
Spartan RC Spartan RC - Quark, DS760 Gyros and other Spartan RC Electronics Factory Support
Old 11-05-2008, 12:38 PM   #1
kanglou
Default Spartan gyro help on logo 5003d
Hi!!
I have done the set up after the install movie here on Helifreak but my tail is just waging.My rate is down in 63% in rate mode 1 my throtel curve is 100-100-97-100-100 in idle up 2 and it still wagging i have chek my ball link is mounted 14mm from the servo shaft and i have around 8 degrees,my servo arm is 90 also.My tail servo is a Futaba 9257 and i have one blue blink on my gyro.I have also chechk my end points and they are fine too. is my servo too slow or what sould i do?I hope you can understand my english.Daniel.
kanglou is offline        Reply With Quote
Old 11-05-2008, 03:20 PM   #2
Nutsinboltz27
Hey whats up? That tail servo is fine, and is not too slow. First of all, the way your throttle curve is you might as well move point three up too 100 or move all the other points to 95 if you want a lower headspeed, the way that curve is, thats enough to cause some tail problems. Also, just use rate mode to set your hover tail blade pitch, do not fly in that mode. The last and probably the most important thing...I believe the ball link on your tail servo horn is way too far out. You should probably have it from anywhere between 8-10 mil and no more than 12 mil from center. I have heard that logos have very good tail authority. Unfortunately I have no experience with setting up logos or the spartan gyro, you will probably receive better help in the logo section of this forum. But you can try the things I have mentioned for a start.
Trex 600N OS55HZ-R Funtech Pipe Edge Blades Edge Tails Edge Paddles BLS 451 cyclics BLS 251 tail Gy701 gyrogov JR DS9411 Throttle Spectrum AR8000 Arizona Fromeco Switchglow Pro FlightPower EonX Lite 2500
Trex 450,Thanks Marv!
Nutsinboltz27 is offline        Reply With Quote
Old 11-05-2008, 10:46 PM   #3
kanglou
ok i will try to move the ball link then thank you for your time.Daniel
Old 11-05-2008, 11:10 PM   #4
Nutsinboltz27
Hey no problem.
Old 11-05-2008, 11:54 PM   #5
emag remrofni
Yeah 14mm is too far out. Move it in and post your results.
Avant > all
emag remrofni is offline        Reply With Quote
Old 11-06-2008, 04:11 AM   #6
MarkWebber
If rate mode is 63% (rather high), what is your HH gain?
Mark Webber
wai-rc.com
MarkWebber is offline        Reply With Quote
Old 11-06-2008, 07:35 AM   #7
Big Fil
Also your blue led should not be blinking which indicates that the gyro did not calibrate correctly. To fly you should either have a solid light in HH mode or no light if you want to fly in rate.
Another thing i'm not sure is causing your problem but may be of some concern for flying is the tail servo. The 9257 is a mini servo and a Logo500 should be using a standard sized tail servo like the 9254, 9256, BLS251, or JR8900G.
Your servo arm spacing is fine at 14mm.
No offense but please don't follow Nutsinbolts27's advice as I feel it is misinformed and admits he has no experience with either the heli or gyro. I have a Logo5003d that had a spartan on it before moving to vbar. 14mm is the suggested distance from Mikado
Mikado Model Helicopters
Edge Blades
Big Fil is offline        Reply With Quote
Old 11-06-2008, 09:58 AM   #8
kanglou
Hi!!
my led is not blinking when i drive it(HH), but in the setup mode i have one blink sorry for that to answer mark webber i have a dx7 radio and in gyrosens it stands rate i think that the same like gain.I think i will buy another tail servo whats the best for this heli?Thanks for your time i hope the tail stop wagging after the new servo.Daniel
Old 11-06-2008, 04:26 PM   #9
Big Fil
Go for the Futaba BLS251 or JR 8900G. Both are great servos.
Edge Blades
Old 11-06-2008, 05:46 PM   #10
OICU812
+1 on that.
Mikado Heli
Scorpion Motors
Western Robotics RC,
Youth Generation Electronics
OICU812 is offline        Reply With Quote
