Old 11-08-2008, 07:59 AM   #1
JBuck
Default ESC choice
Im looking at getting a new scorpion ESC.
Im running the scorpion 8 motor with HS65mg servos.
Should I get the 45amp or the 60amp?
The 60amp has a 6 volt bec but is 20 grams heavier. Will the 6 volt bec make a differenc or should I just get the 45 amp with a 5 volt bec and 20 grams lighter?
T-Rex 550E, T-Rex 450 Pro, T-Rex 250 SE, Blade MCP X, Funjet Ultra, 3DHS 41 Edge, DX7, BC6
JBuck is offline        Reply With Quote
Old 11-08-2008, 08:24 AM   #2
GunnyGlow
I"d rather have the weight savings from the smaller ESC. And I doubt you will be taking advantage of the 60A on the other one.
I use a CC BEC on all my heli's. I"d go that route with the 45A ESC.....then you can program it to 6V if you want.
GunnyGlow is offline        Reply With Quote
Old 11-08-2008, 09:30 AM   #3
Rosebud6
I run a CC45a with a 10a cc BEC (was on sale $5 more than 35a) and the warmest thing on the heli is the battery @ 110 running 3050 RPM.
Rosebud6 is offline        Reply With Quote
Old 11-08-2008, 12:32 PM   #4
pwoodyp
A friendly FYI: Be careful if you do choose to go with the Scorpion as there are a couple of low end ESC's that are designed for planks which are unsuitable in heli's. Forget exatly which models just make sure you check the spec's, the ESC's that are best in heli's will have the "Soft Start" feature! The ESC's I'm talking about do not
pwoodyp is offline        Reply With Quote
Old 11-08-2008, 02:30 PM   #5
emag remrofni
How about the cc 35? Great esc and can be programmed on the computer.
http://modefosheli.com/inc/sdetail/1760
Avant > all
emag remrofni is offline        Reply With Quote
Old 11-08-2008, 02:32 PM   #6
DominicD
The Capi
The 45A scorpion esc will be more than enough for the -8 motor. The V2 scorpion esc are designed for helis, but skip the crappy gov function and use flat throttle curves. The esc works great out of the box with scorpion motors you just have to enable the soft-start (which is overly soft IMO).
DominicD is online now        Reply With Quote
Old 11-08-2008, 05:24 PM   #7
climbing-n-flying
I just got a CC45 and plan on running 4s, so I thought to get the CC BEC. I read that there is a prob. running one of these with a JR 790 Scan Select RX. Is this true, or can I run it and be safe?
The day I STOP learning new trick's, is the day I DIE!!
HDX-Align 450
Align 600
climbing-n-flying is offline        Reply With Quote
Old 11-08-2008, 05:38 PM   #8
Heli-RND
CC 45 for sure
www.Heli-RND.com - we ship worldwide free; SK 720, SK 360, DS 760, GyroBot .....mostly FBL only, the good products only
www.Heli-RND.com
Heli-RND is offline        Reply With Quote
Old 11-08-2008, 05:46 PM   #9
climbing-n-flying
Sorry, I think I wasn't clear enough. Will the CC BEC work with the RX. I can't find the link now, but it was saying there was a conflict w/ JR & Spectrum RX's. I really didn't understand the way they explained it.
Here is the link:
http://www.castlecreations.com/products/cc_bec.html
HDX-Align 450
Align 600
