| Gas, Glow and Turbine Helicopters *No Commercial Ads - Liquid Fueled Helis Only |
This is a T-Rex 600 Nitro Pro with all the metal blue anoidized parts except the blade grips. I find the metal blade grips are much harder on the dampening system. It even has the metal bearing blocks on her as well. The Thunder Tiger Redline 53 motor has had about 3 gallons through her and is broke in well. Here is the breakdown of what is included and installed on this heli.
3 Futaba 9452 Digital Servos - Cyclic 1 Logitech 6100 Gyro and matching brushless servo for tail Align 2-in-1 with remote glow and led status indicators for battery Align governor, very easy to program and very stable Align metal fan with both magnets installed DX7 Heli Radio with receiver that comes with radio, already installed and radio already programmed for 3-D flight and with governor / Strap 2mm Frames throughout, not the 1.6mm frames, when I bought this heli I knew I wanted to put the heavier grade frames on her. 2 Align 1900mah Lipo batteries for the servos and receiver All blades; tail/main/flybar are Curtis Youngblood Align Blue anodized metal bearing blocks Brand new bearing set from RC-bearings, Stainless Steel for motor when needed Also throwing in starter that already has battery pack T-Rex 600 Nitro Spare parts Also throwing in a brand new CSM carb smart still in the bag.. Also throwing in 4 DS-821 servos, three of which are band new and never been used... This heli is in beautiful condition and flys awesome. Very smooth flight characteristics and popping 3-D. I have already, for the sale, replaced the dampening system for you as well as all the bearings in the three main bearing block heads the main shaft slides through. There should be literally nothing to do except fly this bird. I will also be including the original, greenish/gray metal parts for the head that came with the heli as well and their associated plastic parts. The only things that I have noticed looking at this bird is there is a small dent in the MP5 CY Muscle pipe in the lower front from bringing it into the house and hitting it against the outside wall. It is difficult to see anyway unless you are looking at the bottom of the heli above your head. There are two marks on the swash from the common phasing pin issue hitting it at one point. The Align 2-in-1 had a little fray in the wire so I soldered it at that point and taped it, like this when I received it from the LHS and the guy said I did it, anyway, all is well though. Also, I have put a nut on the tail boom gear box assembly. There is only the one bolt holding this gear box on and I did not feel comfortable, after seeing friends tail move or rotate, with leaving it the way it was from the factory. So I loctite the nut on the bottom of the bolt and have never had any issue with it coming loose and it also allowed me to tighten in down much better on the tail boom. The heli throughout wherever there is metal to metal has loctite. It was built maticulously and all wires are secured and routed. Selling it to get into something else.. Last edited by jessegodsey; 11-09-2008 at 06:59 AM.. |
Bump
Without radio and receiver for $1,100.00
Are you interested in parting with your starter?
