Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Gas
MA Gas Miniature Aircraft Gas Helicopter Support Forum
Old 11-11-2008, 02:34 AM   #1
RC_Feen
Question Carb throttle setup after front to rear setup?
I just changed the engine setup from front to rear facing. In setting up the throttle linkage where should the ball link be? On the inside closer to the engine or torwards the outside near the air clearner? I tried to follow the Finless vid's but just need some better visuals/pictures of current setups. Currently I have throttle valve setup with the ball on the carb torwards the outside near the air filter. I'll take some pictures later this evening. Thanks!
RC_Feen is offline        Reply With Quote
Old 11-11-2008, 06:50 PM   #2
geepfreek
towards the engine
I hate the gravitation reminder
geepfreek is offline        Reply With Quote
Old 11-11-2008, 11:57 PM   #3
rbort
Default Towards the engine
And drill a second hole in the arm closer to the pivot point and move it away from the engine some more otherwise the throttle pushrod can rub against the fan shroud.
-=>Raja.
Raptor 90, Hanson 300, 267 flights
MA 1005, Hanson 280, 4060 flights, Spectra-g, Hanson 270, 3140 flights
Whiplash-g V1, Hanson 270, 1320 flights, Whiplash-g V2, Hanson 300, 45 flights
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is online now        Reply With Quote
Old 11-12-2008, 01:11 PM   #4
RC_Feen
Default Got it!
I watched the part 2 Spectra build video again and got it figured out. Now I have to get the receiver installed and start setup. Thanks for the info guys!
