Old 11-12-2008, 01:47 PM   #1
sgrim80
Default Hyperion duo - Charge 3s lipo without main leads
How do I charge a 3s pack on my Hyperion duo without using the main charge leads? Its a 3s 2500mah lipo for a tx. I set the charger for 3s and 2500 mah but I keep getting an error when I try to charge with only the balance taps connected. My cellpro 10s used to do this just fine.
Steve
sgrim80 is offline        Reply With Quote
Old 11-12-2008, 06:52 PM   #2
nargargle
You have to use the main charge leads. The balance tap only bleeds off excess voltage from each cell as needed to keep the pack in balance. It will not charge through the balance taps.
Hirobo Lepton EX, Kyosho Caliber4, JR Vibe 50, JR Vibe 90SG
Foamy Corsair and Habu, MCX, MCX2, all on JR 11X
nargargle is offline        Reply With Quote
Old 11-12-2008, 08:38 PM   #3
sgrim80
sh*t!
Old 11-12-2008, 10:41 PM   #4
TheBum
A charger like the Hyperion DUO is designed to charge large packs. The balance taps are not designed to take the current required to charge at more than about 2A and it doesn't make sense to support two different charge modes.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is online now        Reply With Quote
Old 11-13-2008, 06:39 AM   #5
sgrim80
What I need to charge is a tx lipo. I guess I'll have to rig up some sort of adapter for the main pack leads. It has a JR/Spektrum tx connector on it. Wonder where I can get the tx side of that?
Old 11-13-2008, 07:04 AM   #6
TheBum
I understand where you're coming from now. That's one thing I like about the Kong Power TX pack in my DX7: it has two power leads, one for JR/Spektrum and one for Futaba. The Futaba connector is just a standard servo-type connector and my "squid" charging lead has a connector that works for it, so I can charge it without disconnecting it from the TX.
HeliFreak Support
Old 11-13-2008, 01:35 PM   #7
jkelling
I have a hyperion (not duo), and I understand your pain. I have so many different change leads (deans, traxxas, ec3) - I really am looking for a charger that can charge through the balance taps only. Or even better - give me the choice of hooking up the high current discharge leads for faster charge rates, or using just the balance taps for slower charge rates and smaller batteries....
jkelling is offline        Reply With Quote
Old 11-13-2008, 01:58 PM   #8
TheBum
Are you willing to live with a charger than can charge at a maximum of 2A (< 1C for typical 450 packs)? DN Power makes such a charger. I'll sell you mine.
Those are completely different charging implementations, essentially requiring two chargers in one unit and a means to switch between them. Even if somebody did do that, I would expect it to drive up the cost by 50% over a single implementation.
HeliFreak Support
Old 11-13-2008, 05:53 PM   #9
sgrim80
Cellpro 10s...just sold one to buy hyperion duo.
Old 11-14-2008, 04:57 AM   #10
RC Accessory
Here you go: http://www.rcaccessory.com/index.asp...ROD&ProdID=350
RC Accessory is offline        Reply With Quote
