Old 11-24-2008, 07:28 AM   #1
jvthert
Default Radix or Align (or sg. else) tailblades?
Which blades would be better and why? Align 3K carbon 70mm or the new 72mm CY Radix tailblades (YEI-YB-72)?
jvthert is offline        Reply With Quote
Old 11-24-2008, 09:16 AM   #2
brian94066
had the Align CF for my 770 on the 500
it hold good, but it drifts in fast backward flight
and tail strikes are alot more visible, and the blades get ugly really quick
changed over to the Radix 72mm and boy what a difference
it looks better, it's shaped better, and it's perfectly balanced
the tail holds rock solid and the blades are so durable
brian94066 is offline        Reply With Quote
Old 11-24-2008, 09:43 AM   #3
chucky21022002
Shame. I just bought Align carbon ones. Im using K&B at the moment and when I compared it to the Align, Align is smaller than the K&B ones. Im happy with how the k&b holds the tail at the moment but I hope when I change it to the align carbon, it will be better.
Gaui X3 Fubar Trex 500 Vbar
Trex 550 Vbar Compass 6HV BD3SX
Compass 7HV HC3SX Compass Chronos HC3SX
chucky21022002 is offline        Reply With Quote
Old 11-24-2008, 10:11 AM   #4
jvthert
I'm already flying 3K carbon (not the 700 version but the 70mm 500 ones) but would the radix tailblades make any difference?
[edit]
Oops you meant your gyro, not T-rex 700. Haha! So you think the radix blades give a better hold?
[/edit]
Old 11-24-2008, 11:02 AM   #5
beeflyer2
I can't tell a difference between KBDDs and Align CFs in flight.
Team Synergy / Rail Blades / Morgan Fuel
beeflyer2 is online now        Reply With Quote
Old 11-24-2008, 11:19 AM   #6
jvthert
That's the magic of your spartan Put a 401 on your tail and you'll notice the difference. K&B's are great compared to anything plastic but compared to carbon there's a world of difference!
With 3K carbon blades and the standard settings on the spartan it's like the tail hits a brick wall when I center my rudder stick I have to tame it a bit in the decelleration profile! I just wonder if my tail will bend when I switch to CY blades
Old 11-24-2008, 11:47 AM   #7
hawkins221
radix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!yep
hawkins221 is offline        Reply With Quote
Old 11-24-2008, 04:57 PM   #8
ualdrivr
The Radix tail blades rule, they are wider chord than the Align and any other blade I've seen out there. They add great turning and stopping power, love them
http://helifreak.com/album.php?album...pictureid=9476
Hope this helps.
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote
Old 11-24-2008, 05:13 PM   #9
hawkins221
Old 11-24-2008, 05:24 PM   #10
jitavits
+1
I've 401 on my tail and been using K&B blades for a while. Then I put the Align carbon blades on, I can notice the different. Its has no different in holding but the tail stops lot batter that the K&B.
jitavits is offline        Reply With Quote
Old 11-24-2008, 05:35 PM   #11
brian94066
Hope this helps.
+1
people really need to give these a try =]
Old 11-25-2008, 05:00 AM   #12
jvthert
Thanks guys. I'll give them a go!
Haha, stop drooling I'll get a pair for the tail but I decided not to buy the main blades. Red devil SAB blades for me!
Old 11-25-2008, 09:15 AM   #13
brian94066
radix are heavy, makes for smoother flights
i stick with stock align white CFs for faster cyclics and more pop
hell, even the crappy align 425D flies like the radix o.O
