| Belt CP E-Sky Belt CP |
Ok, for christmas I am getting myself a 6s charger. I have been trying to find a power supply to work with a thunder power 610c charger. So my question is...
Will this: http://www.cmfhobbies.com/ULTRAPOWER...-240V/1032.htm Work with this: http://www.fast-lad.co.uk/store/inde...page=2&sort=1a Thanks to Boddan for telling me how to make one for myself. But seeing as christmas is coming I thought I might as well add a power supply to the list. Also, I suck at making things. I could try one day though lol.. Any info or advice appreciated. EDIT: I would like to also thank copterboy for letting me borrow his charger while I looked for a better one. Thanks -Jonny
Spektrum DX7, Align Trex 250se, Align Trex 500cf, Align Trex 600n LE |
No Probs J, glad it helps. My friend has just got a T-Rex 500, and is building it up at the moment. As my 450 t-rex is down till crimbo, I've lent him my spektrum Rx!!
I can't wait to see it fly ( and secretly hope he'll let me have a go one day...lol) I'll have to let the others guide you on the PSU though as mine is borrowed from same friend, and I've never looked at buying one yet!! Only 30 days to go is it?? ![]() ![]() ![]() Bad news if your ordering from deal extreme!!! ![]()
COPTERBOY To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. DX6i, mSR (SOLD), BeltCP (SOLD), mCPx w solid boom and Rakon Heli Head T-Rex450V2 w.PRO head, Scorp-8 & 45A V2 ESC, CSM4200/S9257, 3xHS65MG E-Flite CX2 - All Microheli/Extreme CNC CF Upgrades TRex600N, Kasama Head, OS50SX |
Jonny,
I don't know. Mine is a 20A power supply and when I try to charge my 600 batt it only charges at 3.3 or so amps. I don't know how all that electrical schtuff works amps and joules and newtrons and whatnot. I don't know if you multiply amperage times number of cells, that works out about right. I tell the charger to charge at 5.0 amps (for a 5000mAh batt) but it winds up maxing out at about 3.3. (which times 6 = approx 20 amps) I don't know...anyone else smart on this. Is my 20A power supply limiting my charging cpability? *edit* Nevermind...just checked the specs on my charger and it says max input 12v @ 10Amps so I would assume a 10 amp PS would be fine. But, no, really...I'd talk to somebody way smarter than me. LOL
"It was a controlled descent!" T-Rex 600 GF, 600XL, Stock ESC, 11t, Align DS610's, s9251,GY601 gyro, AR6200, ZIPPY 6s1P FOREVER! |
Jonnyheli
The Ultrapower ( if I may believe the specs) will do fine , I don't get the second link dough testpilot58d Can you post your equipment you use (charger ,power supply) I may be of help
Anything that flies |
Johnny
I'm selling my TP-610c. Comes with a Duratrax Compact Power Supply. 4 months old. All for a 45% discount. http://helifreak.com/showthread.php?t=105054
#6 |
That power supply will be plenty powerfull enough jonny.
Basically your charging around 12v, which is roughly the same as the input to thwe charger. So if your charging at max around 2.2-2.5A to the batteries that means you should only be drawing 3A absolubte max from the power supply at that rate so 10A is plenty Brain, Your charger is probably limiting the charging speed then. If you can only have 10A input, and your charging a 6s pack on it thats an average of around 24v to the pack, so your current drawn from the power supply is doubled. That means if you want to charge at 5A your going to be drawing 10 plus the power to run the charger. So say 11A, Thats more than your charger can take. When the battery is getting full, the voltage will be getting to 25/26v, which will mean your charger again can only charge at 4.6A if it was 100% effecient. 3.5A ish is what i would expect with losses from the charger etc. Kianhon's is a very nice set-up, but not sure what it would cost to get in the UK?? The thunder power charger is excellent, i have the larger 1010C version, and my neighbour just bought the 610c.
Sponsored by - Team Align UK- CSM - MKS Servo's UK - Kontronik Drives T-rex 700E v2 - 700E DFC |
#7 |
Ber,
My equipment: Maxpro X6 http://www.himodel.com/electric/Maxp...t_Charger.html 20 Amp Power Supply http://www.hobby-lobby.com/powersupply.htm Grant, I think I understand what you are saying. Basically because the charger is limited to 10A coming in on 12v, and I'm charging at around 25v to the batt, the charger is doubling voltage internally which doubles amperage draw. So .. 25/12= 2.083 ratio internally lets say 1 amp to run the charger...maybe 2 when the fan is on. Leaves 8 amps to work with. 8/2.083= 3.84 Sound about right? Thats about where the charger is limited at when charging 6s
#8 |
Brian you just earned a A+
#9 |
Johnny I've made the power supply that Boddan suggested it is simple and if you already have a pc power supply(like me) it only cost $4US to complete a 12v 15-20+amp supply!(depending on the wattage)
if you can use a drill and a soldiering iron you can make this power supply! I've been using mine since Halloween!
-Heli Yea! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Master of: the living room, stockTx, mechanical setup and, the obvious! Belt'ish CP MG90's,704A/S3114,CX head,HDX3550/Align 35G/HDX 500 SAH:-) HS-82MG's,G401B/BMS-631MG,HDX850/Align 60G,6s lipo /Hirobo Shuttle ZX .30 /Walkera 4#3B/Falcon40/Lama V3 DX6iThank you kind gents! :-) |
#10 |
Hi Brian, Just to chip in a little, I don't think your power supply is limiting your charge rate, it is more than man enough for your charger. As far as I can see, from the specs of your charger, it is simply a case that it has a maximum power 'output' of 100W, no matter how you break it down between current and voltage. Very roughly, in your case, you are charging a 6s pack which will require 25V. From P=IV you can see that this only allows for a maximum charge current of 4A. It is therefore not surprising that in practice you achieve a little under 4. This may in fact be a function of the output voltage of the charger being a little higher than the required 25V. In terms of voltage the output stage of your charger is limited to 32V, so it is probably somewhere between 25V and 32V when charging.
This seems right to me, but as always I am prepared to be told otherwise, lol.
Regards, Sutty BeltEXI, mCX, mSR, 4G3, FBL Trex250SE µB, FBL Trex450Pro µB, FBL Trex550e VX1, FBL Trex600ESP µB, Parkzone P51D |
#11 |
Voltage times amps being drawn shows watts produced. Watts divided by voltage shows amps being drawn or watts divided by amperage shows voltage applied. Does that help?
#12 |
I just said that.
Edit: Sorry, just being silly, I actually said P=IV
#13 |
Ok, lot's of good replies. I don't have a clue what you guys are talking about lol. I can't think straight at the moment because there are too many replies to read.
All, I know is that the thunder power 610c charger can take a max of 10A (80 watts apparently) at 11-16V. The power supply is 10A 12V So I thought it would work. Will it go faster the more volts it charges at? That is a 12V. So does this mean it will go abit slower? What charge times should I expect from this charger with that power supply? And how many amps should I charge at? Or is this automatic??? I seriously know literally NOTHING. I am just following what the specs say. Copterboy. I hope he let's you have a go Because if he does I know you will be coming home with one lol. Even when you see it flying you are going to want one.kianhon, if you were in Britian I would consider your offer but for the postage and the currency has gone s**t and the wait for it to come from America I would rather pay a little extra and get it here. But I'm sure they will get snatched up by someone else quickly. Thanks for all the info. It has helped me (Sort of) Big question is. Should I get this power supply for the TP 610c or is there a better one for the same price? And what charge times would I get from this PSU. -Jonny
#14 |
Sutty,
From the link I posted: "1. Input power capacity: 11~15V DC 10Amp at maximum charge rating" Jonny, You tell the charger how many amps to charge at based on your battery. If you have a 2200mAh batt you would charge at 2.2 amps This is standard practice . charging at '1C' My kongs and AirThunders are rated to be charged at 2c no problem (which I have been doing for prob 100 cycles with no problems) so I tell it to charge at 4.4amps If you connect (2) 3s batts together in series ang plug in both balance taps the charger will see it as a 22.2v 6s 2200mAh battery. Same thing..tell it to charge at 2.2 amps(unless you want to do it at 2c which would again be 4.4) You shouldnt need to set any voltages in the charger except you can change defaults for max voltage/cell (4.20) min voltage/cell for discharge, cycling, or voltage level for storage charge. Output voltage to the batts though, the charger does all of that.
#15 | |
If you charge 3S1P batts with it, you can charge easely up to 7 amps.(I don't recomend doing that Like Grant_beltcp said : That power supply will be plenty powerfull enough jonny.
#16 |
Hi Brian, Also from your link:
The maximum charge/discharge voltage is 32V. 3 . Charge current is adjustable in 0.1A increments from 0.1A to 5A with the maximum rate of 100W. Hence at 25V, maximum of 4A.
#17 |
I see what you're saying. I misread your last post. I thought you said my CHARGER isn't limiting me. I see now it says Power supply.
..and did you really just say 'Hence'....lol
#18 |
Thanks Brain, so a 3000mah battery would need to be charged at 3amps etc...
I love this forum -Jonny
#19 |
"hence"
Its a british thing ![]()
#20 |
What's wrong with hence, it's a perfectly cromulent word!
