Old 11-28-2008, 11:54 PM   #1
Flyextreme
Default 450 SE manual
Are there any other options on veiwing a manual for the 450 SE? I can't seem to get the ones from the "sticky" to work on my computer. I only need a parts list.
Thanks, Bill
Flyextreme is offline        Reply With Quote
Old 11-29-2008, 07:21 AM   #2
Nogyro
Rotowrecker,
I downloaded the SE Ver 2 manual yesterday. The zipped folder contains one .pdf file which should be viewable with a copy of Adobe reader. Did the file download? extract? not launch? Is it the SE ver 1 manual?, etc.
Nogyro is offline        Reply With Quote
Old 11-29-2008, 10:16 AM   #3
pwoodyp
Also need to be logged in to get the download.... otherwise what Nogyro said the *.pdf should be readable after extraction from the zip file with the Adobe reader
pwoodyp is offline        Reply With Quote
Old 11-29-2008, 11:54 AM   #4
RCSavager
The "trick" to the site is to go up top and log out. Then when you log in check the little box that says something like "remember me dammit". That will keep you logged in when you try to pull from the download server.
RCSavager is offline        Reply With Quote
