| Register | FAQ | PM | News | HF Locator | Groups | Blogs | Calendar | Mark Forums Read |
| 250 Aftermarket Upgrades 250 Aftermarket Upgrades |
These are videos of :
I had this tail assembly to design the chinese weights for the T250. But first I had to get the tail assembly to work smoothly enough to do the testing. I am not bashing Align!!! The things that you see in the video are problably not typical. this was probably a bad tail. This video is just to help those who might not know how to diagnose a mechanical problem. These are areas to look at to find causes of excessive drag. Your tail may have none of the issues seen in these videos. TAIL BINDING PART 1 http://www.youtube.com/watch?v=9WmzpeQY6YA TAIL BINDING PART 2 http://www.youtube.com/watch?v=-Y1UBDJaNVo Comments:
These are videos of:
SPACER UPGRADE & CHINESE WEIGHT PART 1 http://www.youtube.com/watch?v=gP2OYVEjU0Y SPACER UPGRADE & CHINESE WEIGHT PART 2http://www.youtube.com/watch?v=8IOXbuMOJfU Comments:
PLEASE DONT PM ME OR INQUIRE IN THIS THREAD UNTIL I POST THAT THEY ARE READY!!!!!! IT MAKES DOUBLE WORK FOR ME TO ANSWER PMS INQUIRING BEFORE I HAVE THEM AVAILABLE. Thanks for your patience in advance, HEIM JOINT Last edited by HEIM JOINT; 12-08-2008 at 09:39 PM.. |
HEIM JOINT
thanks for all your time and work on this! |
Yup thanks, that looks so cool, add me to that list!
I watched your vids last night. Good stuff!
Heim Joint,
You are undoubtedly The Man! From the time you spend to make these mods, to the time spent in explanation of theory in all you do. You and Finless are top notch examples of knowledge applied in our sport. I commend you for all you do and look forward to future advancements that you will surely take part in. |
#6 |
Can I get on a preoder list? I want these BAAAADDDD. They do wonders on my T450, and t500. TKS MAN!!! YOU ARE GREAT!
T-Rex 250 super combo T-Rex 450 PRO - I love this little guy! T-Rex 450 SE V2 - Sk360 in Airwolf fuselage T-Rex 500 Blinged to the extreme - Sk360 - Gy401/S9257 - 5045MGs T-Rex 600 LE - KDE everything, waiting on RL53 Raptor 50 eCCPM 140- QuickUk everything - G7703D/S9254 - S9252s - RedLine53 |
#7 |
Awesome job throwing these vids together, let alone the in depth detail you go into.
I was skeptical about the effectiveness of chinese weights on a model this small. You totally blew my theory out of the water. I was wondering if your only reason for placing the bearings in the polarity you chose was to cup the grease (as was explained in the video). It seemed to be that when simulating a load on the bearing (pressing the stack towards the head of the bolt), action seemed smoother with the open end facing the bolt head (which forces the bearings into their races). Do the bearings have polarity or are they just as effective in either orientation? Please put me in the queue for the bearing and chinese weight mods. Again, nice work and thanks for taking the time to put together undisputable evidence of your findings. |
#8 |
Just watched all 4 videos. Very nice work. Really, exceptionally well done.
In one of your other videos, you mentioned it was probably a good idea to keep trivial forces on the servo with any "chinese" weighting, instead of a true zero load. I tend to agree as any servo gear lash, linkage slop, etc would only be felt at the transition from/to 0 pitch (instead of throughout the range). In this video the weights pretty much show zero forces until the end (and may even go negative?). The sheer size of the weights in relation to the grips is pretty amazing. Thanks for the info! ![]()
12S v-bar'd T-rex 600 and 6S t-rex 450 Pro |
#9 |
[quote=heli-on;998277]
I was wondering if your only reason for placing the bearings in the polarity you chose was to cup the grease (as was explained in the video). It seemed to be that when simulating a load on the bearing (pressing the stack towards the head of the bolt), action seemed smoother with the open end facing the bolt head (which forces the bearings into their races). Do the bearings have polarity or are they just as effective in either orientation? quote] A Standard radial bearing has no direction. Its thrust capacity is the same either direction. On larger bearings the ball cage or retainer is symetrical and the direction to cup the grease would not apply. On these very small bearings the ball cage is not symetrical and does have a "cup" direction. On some of these blade grip bearings that I have seen that I would consider poor quality, it looks like the retainer may stick outside the bearing faces under axial load and might rub whatever is next to the inner race. This may be part of the "binding problem" since just changing to another bearing set removed 90% of the drag. HEIM JOINT |
#10 |
SOB.... I'm sold!!! Great work man and sign me up for a kit when ready!!!!
