I just tried to verify my Align RCE-BL60G was correctly setup to output 6V to the electronics. I tried to do this by connecting a small extension lead to the bat port of my AR7000 and then use a multimeter to read the voltage off of the pins in the open connector. The only result was a small click in the ESC. Yipee, my hand must've slipped causing me to short the sucker.
There goes another $90. Note to self: never do that again... ![]() At least now I don't have to find out if the built-in BEC is good enough. |
Awh man!! I'm sorry! I hate it when that happens. We all have a brain
now and then. I guess those are the lessons we'll not soon forget, eh?Get back in the air soon. Hoot
Trex 500 CF: 3x DS3517's, ds760 w/9257, 12T, Grey Dampers (for now) Trex 450SE V2: 3x HS65mg's, GY-401 w/9650, 12T, TB Dampers Blade CX2 (Doesn't everyone) To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. RealFlight G3.5 AMA#895105 |
I took a servo extension cord and cut it. Then, I removed the signal wire. Finally, I cut the red wire about 10cm shorter than the black wire. No chance of shorting them out.
She felt like someone of an ambiguous age that even neilg would approve of... |
why spend 90$ when you can fix the esc ?
if you are not afraid of soldering, you should read this thread, otherwise, send it over to me and I'll fix it for you (given it is the same problem as i expect it to be). I'm expecting a letter with 2 Mosfets (the part that usually blows inside the ESC) from MTDV, so I'll have 1 spare and I'll be happy to help, |
WoW! That's really cool of you, Lavi.
#6 |
#7 |
Just add a BEC to it. CC makes a good one..
Or Have Lavi fix it for you.
In a world of compromise, some don't! |
#8 | ||
I'll PM you, it would be nice if the ESC could be repaired. I carefully opened up the ESC and the broken IC was indeed the 4425 MOSFET. I had a look at datasheets for compatible parts (Microchip and Micrel) and what surprises me is that it lists a 3A peak output current. I think Align lists 3A continuous with a 5A peak. |
#9 |
The internal BEC on the ESC likely provides the power for the ESC electronics as well. If this is the case and the MOSFET failed, then the ESC will not power up.
T-Rex 500 |
#10 |
#11 |
Yep, did a similar thing here. Removed a servo wire and replugged it but I must have moved the pins across when plugging back in. Nasty smoke came out the esc, very silly thing to do, I should have just disconnect the batt first when replugging and checked properly..
#12 |
W00T! I went to the post office today to pick up the ESC Lavi generously fixed.
It's great to have it back, thank you very much Lavi. ![]() If anyone else screws up the BEC in their ESC and knows someone with SMD soldering skills, PM me - I still have some suitable replacement MOSFETs I'm willing to give away. |
#13 |
Lavi is Da Man! What I did to test mine was to use a male/male connector. Plugged one male into the rx and used my load meter to check voltage. I set the esc to 6v but when I put a load on it (1 amp) it held 5.8v. Maybe that's why people are getting away with not using a stepdown for tail servo. I use the step down regardless.
#14 |
Great !!!
Very happy to help. and even more - Very happy that you will be back in the air soon. also, mjbrands sent me some extra mosfets, so if anyone else has a smoked BL60G, but no SMD soldering skills, I will be happy to help. just send it over and I'll fix it. Lavi |
#15 |
Hi . I read your post on fixing the 60 amp esc's. I have 2 that I fried and I know I cannot fix them. Any chance you can help ?
Thanks -Jeff |
