| 250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I had it with this heli !!!!!!
The servo’s are junk!!!!! The gyro is a joke!! The screws are junk!!! The tail is a piece of !!!!Do not buy this heli !! Don’t throw your money out the window like I did!!! ![]() |
Tell us how you really feel.......
Terry MAAC#78357 IRCHA#3269 AlignT-Rex 450 SE V3 2221-8/ Align T-Rex 600N,OS55HZ / Align T-Rex 600E 12S A123's / Align T-Rex 700N YS91SR/ Bergen Intrepid EB Zenoha 260/ |
Sorry but that made me feel better..
My instructors just split the spindle shaft in half while hovering apparently. Not quite sure what to make of that right now.
I love my 450 but I HATE my 250!
#6 |
Take it easy...
I had the same thing happen with my 450, threw it in the trash once!, I walked away for a while, then got some help, and now it is on my fav to fly list!
No Plankers were injured in the making of this post! TOY BOX contents Mcp x, 450 Pro VBar, 500 VBar, 12S 600CF VBar... Mikado Logo 6003D VBar Proudly flying KBDD, MKS, Castle, Scorpion and some planks too To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#7 |
Do you have the new hb/bearings on?
My tail is ROCK SOLID. Today i did some fast backwards circuits, high tail slide and big sideways loop and it didnt even give the slightest wag. This is with everything stock accept the tail servo, which is the HSG-5084. My tail was truely crap before the new hub.
Sponsored by - Team Align UK- CSM - MKS Servo's UK - Kontronik Drives T-rex 700E v2 - 700E DFC |
#8 |
Grant, the new tail hub doesn't cure all ills. Not for all of us. In fact, the new hub is identical to the original hub. I have tried two 1.2mm bearings per grip (upgrades from stock), as well as one 2mm bearing and two 2mm bearings per grip (Gaui part). Spacers used within as appropriate. My tail assembly is fine mechanically... I'm convinced. I can't lock-in my tail in any of the above scenarios. I even messed with the two tail blade configurations, including cutting down a set as was suggested elsewhere. Among all the other changes mentioned above, I've played with head speed and gyro delay. Nothing has worked. By the way, I've been using a JR DS290 tail servo for all the tests, which many have had success with.
I'm going to order a Spartan gyro. I can't come up with any other things to try. |
#9 |
Very strange. Theres 3 trex 250s that fly arond here, 1 mine and 2 freinds. All 3 were sper combos and all three had tail issues. As soon as the new hb and bearings were in all 3 of us had really good tails.
Mine is absolubtly rock solid, stock gyro but the larger HSG-5084 servo. One is using stock servo and hyperion servo, this hold really well during tic-tocs etc but sometimes has a little wag in backwards flight etc. The other is 100% stock and flies well and holds very well but i dont think the stock servo is upto it as it isnt a rock solid hold with abit of wag every now and then. Its 3D capable, just not crisp like mine. All three helis are on the standard settings, 0 delay. Have you tried the new hub and bearings from align (not aftermarket berings etc)? And if so and it still isnt working i would try out the hitec servo i listed above. I'm loving the align gyro so far!!
#10 |
Will the tail from the gaui 200 fit ?
#11 | |
We have one other T-250 in the local club... DesertClimber's. He got the tail locked-in with the 15T pinion and the same setup otherwise as mine, but couldn't do it with the 16T pinion. The Spartan gyro cured his. I figure I may as well just throw in the towel and get the Spartan Gyro now, so I don't go through all this again if I change pinions or go to the CF blades. DesertClimber's T-250 does 3D like a bat outta hell with the Spartan. In a gymnasium, no less. He's got video, and I hope he posts it here. |
#12 |
I will NOT spend $200 for a gyro for this heli!!!!
#13 |
Well, between the super combo, the upgraded DS290 tail servo, a gob of batteries, receiver and spare parts, I already have over $700 invested, so I'm not going to throw it away. Instead, I'll throw good money after bad.
I may have given up until I saw DesertClimber's T-250 first-hand, and it was awesome. I think it's worth the investment. |
#14 |
I hope that it works good for you . Let us know…
#15 |
If it doesn't work, Baby T-Rex is going to take a one-way flight to dumpster-ville
#16 |
At least you will be able to use the Spartan on a dif heli..
#17 |
i love my t-rex. i had an oopsi tonight flying. i was doing aileron tick tocks about a foot off the ground in my friends church. i go to low and the tail hit the ground and took off both blades. i got it kind back in control and tipped the blades on the ground. it took a link, put a crack in the main blades and took the tail blades. the main shaft seemed fine, i still need to check the spindal. i love the little guy though lol.
Dave Ketelhut To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Team Compass USA Gens Ace Prostarhobby.com |
#18 |
What did you have to do to get your tail to work . I’m starting to think the tail servo and gyro are not the problem . I think its all the tail. Did the new hub work for you ?
#19 |
yea the new hub worked great. did you not try it. so far everyone i know that has the new hub now has a great flying tail.
#20 |
That's the spirit! You're not the only one that thinks everyone is crazy for that!
Lynx Team Pilot GrandRC Field Rep BEASTX |
