Old 12-15-2008, 09:28 AM   #1
eroedega
Default Max rpm on Align 325 PRO ?
I want to use them safely. Not risky. Any know how many rpm i can do it safely?
Just started to fly heli, why didnt i start this earlier. Damn fun.
eroedega is offline        Reply With Quote
Old 12-15-2008, 11:53 AM   #2
bio87
I've always heard 2800 but i'd do like 2500 just to be safe.
bio87 is offline        Reply With Quote
Old 12-15-2008, 12:20 PM   #3
gravydrive
2800 according to the manufacturer.
gravydrive is offline        Reply With Quote
Old 12-15-2008, 12:26 PM   #4
Mr.Andersen
The limit fore them are 2800rpm
Some people run them over 3K and someone people have seen them disintegrate in the air so to be safe dont run them over 3000rpm.
I run mine at 2950 rpm.
CopTreX 450 SE V2, Pro..... real bastard.
Logo 500 3D FB
Blade mCPX
Mr.Andersen is offline        Reply With Quote
Old 12-15-2008, 03:21 PM   #5
airsoft1779
i run mine at 3000 set rpm mode for about 100 flights now. still no problems or warping taking place. i dont fly 3d(as hfg said) but do quiet alot of stuff like tic-tocs, chaos and everything you learn before that on woodies and its fine. ive ran at 3100 rpm for about 10 secs but i rly do not feal safe at that speed.
airsoft1779 is offline        Reply With Quote
Old 12-15-2008, 04:12 PM   #6
HydroJoe
I have run them at 3200 rpm for hundreds of flights with no problems. I have seen other brands of woods blow apart but never the pro woods.
T-Rex 600 Nitro Super Pro
T-Rex 450 SE V2 on 4s
PZ 27C Stryker (yea, it's a plank)
HydroJoe is offline        Reply With Quote
Old 12-15-2008, 05:25 PM   #7
airjawed
If you are just hovering then the pro wood is ok for 2800 according to manufacturer...and many do run them faster...
But if you are doing hard stuff then you are probably good enough to not crash and thus using carbon fibers.
I'm using the pro wood at a governed 3000...doing flips and rolls....nothing too hard and haven't had a problem...but it is only because I couldn't get the 3k carbon fibers and just needed to get in the air!
Trex 450 Pro 3xDS410M + MKS8910A+, Align FBL head w/Microbeast, CC 45 Gov@ 3400rpm(max timing, outrunner mode), Scorpion 2221-8 on 14t, Edge FBL main and tail, CF boom, CC BEC @ 6V
airjawed is offline        Reply With Quote
Old 12-15-2008, 06:39 PM   #8
ace22459
If you don't call that stuff 3d, then what do you call 3d?
Blade CX/2, Axe CP, T-Rex 450 SA(SE V2 now) , T-Rex 600nitro Pro, Blade mCX, T-Rex 500 GF, T-Rex 450 SE night rig with ZeroGear and FlexPro lighting, Walkera 4G3, scale 450 Hughes 500D, Hirobo SDX HPM, Blade mSR, DX7
ace22459 is offline        Reply With Quote
Old 12-16-2008, 02:51 AM   #9
Pinecone
Manufacturer says 2800 RPM. Anything above taht, you are on your own.
And think about if it sheds a blade and harms someone, what will teh court case look like? Well, "I know they are rated to only 28000 RPM, but a bunch of guys online said they are fine at higher speeds, so they must know better than the manufacturer." Yeap, you will win that one.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote
Old 12-16-2008, 06:30 AM   #10
airjawed
Not sure about Norway...but in America getting sued is a favorite past time. Perhaps a major contributor to the specs on the heli blade? Not to say one should ignore the specs...I want everyone to be safe...the pilots and the spectators. An almost contradictory statement seeing the overall hobby of heli 3d flying!
Old 12-16-2008, 09:26 AM   #11
airsoft1779
http://helifreak.com/showthread.php?t=105207
i think its post number 36 and 37
Old 12-16-2008, 09:49 AM   #12
Krusty Blade
so when doing your initual setup you have to cater for the headspead?? standard out the box build could destroy the blades... just asking cause i will be completing my 1st heli build soon *TREX 450 SE V1*
"C'est en faisant n'importe quoi qu'on devient n'importe qui"
Krusty Blade is offline        Reply With Quote
Old 12-16-2008, 10:08 PM   #13
seflyer
Angry
Pinecone? are you a frickin cop or what? Mr Know it All here? I am sure all lawyers now all about heli headspeeds and gearing to make that stick.
seflyer is offline        Reply With Quote
Old 12-17-2008, 12:44 AM   #14
Pinecone
Maybe they don't, but if you get sued they WILL find people who do know.
And yes, in the US suing is a favorite pastime, so you can either prepare for it, or deal with the consequences.
Your choice.
Terry
Old 12-17-2008, 06:58 AM   #15
airjawed
Out of curiousity what is the max headspeed for carbon fiber main and since we are on the subject a carbon fiber tail?
I would think with carbon fiber you need to worry more about the feathering shaft bolts giving way. But I don't have anything to go by...anyone have any numbers?
