Old 12-16-2008, 09:19 PM   #1
bobbyshafter
Default Trex SeV2 or TrexSE -CF
Is the V2 worth the extra money i am a noob and need to decide which to order V1 or V2.
bobbyshafter is offline        Reply With Quote
Old 12-16-2008, 09:26 PM   #2
TomRex
For the most part all the last of the V1 kits were updated to the latest and greatest updates except for the 4mm spendel and thrusted grips. The actual frame has been changed a bit between the V1 and V2 but all the bling is the same but for the shade of blue. I've heard a lot of complaints lately on the sloppy fit of the grip bearings lately on the V2 and the V1 grips work just fine unless you need to keep up with the Jones's
there is the same amount of aluminum in both versions and the main shaft is ecactly the same dimention in both V1 and V2. The V2 has a sloppy grip bearing fit that why the grips flap on the spendel.
How much past 200 mph do I need to go you ask?
TomRex is offline        Reply With Quote
Old 12-16-2008, 10:00 PM   #3
blahblah9
how good are the motor's that come with the kit's? I see SE and GF kit's what's the difference? So is SE v1? or is it v1 as long as it don't have v2 behind it?
blahblah9 is offline        Reply With Quote
Old 12-16-2008, 10:08 PM   #4
blahblah9
What all has been changed from v1 to v2? any major probs with v1? well any probs at all with v1?
Old 12-18-2008, 01:42 PM   #5
WickedDragon
The V2 has more aluminum parts and resolves some issues with the V1. Swashplate, bigger mainshaft, blade grips & bearings, tail rotor control. 430XL motor instead of the 430L.... more efficient. General improvements all around! If you're going to buy a new one, buy the NEW ONE and you won't be spending the first $200 on upgrades!
Doug Bonham, WickedDragonRC
Gravity isn't just a good idea, it's the LAW!
TRex250SE; TRex450SE V3 DFC; TRex450ProV2 DFC; TRex600N; TRex600N DFC; TRex600e DFC; Futaba 12Z
WickedDragon is offline        Reply With Quote
Old 12-18-2008, 03:42 PM   #6
snjbird
Yup if I was shopping for one now a V2 would be the heli to have!
snjbird is offline        Reply With Quote
Old 12-19-2008, 07:05 AM   #7
simarRC
or just wait for the v3...
TREX 600 CF, TREX 600 MF, JR X9303/XP9303.
MAAC# 76893
simarRC is offline        Reply With Quote
Old 12-19-2008, 07:20 AM   #8
blahblah9
is their a v3 coming out? or just hopes?
also, i can't believe i forgot this. I have deans on my blade400 and lipos. What comes in the V2 kit, or do i need to order some more dean connetors?
Old 12-19-2008, 07:59 AM   #9
TomRex
They should have a builders kit with stainless screws, custom tolerance machined parts, ceramic bearings, Jazz 40-6-18, Neu 1107h2y, uH drive pulley and tail shaft, Mavrikk belt, hs1173 canopy, Outrage 4s 1800 battery, Maniac blades out in about a week!
Old 12-19-2008, 08:30 AM   #10
blahblah9
for real? sounds expensive though LOL
Old 12-19-2008, 09:46 AM   #11
WickedDragon
Just 1 pair for the ESC & battery. Bullet connectors are included for the motor.
Sure! I bet that TOMREX has one just like it on his bench right now.
Old 12-19-2008, 10:03 AM   #12
blahblah9
Oh so, that's what he has upgraded his heli to huh?
Old 12-19-2008, 10:07 AM   #13
WickedDragon
Just a smidge!
