Old 12-17-2008, 01:08 AM   #1
sokal
Default B4003DX build for lovinmyblade400
well as stated in another thread about the buil im doing for a guy in Iraq
i will be installing
sonix 3500kv motor 13T
scorpion esc v2 45a
cnc frame
cnc sonic (black) head
cnc sonic (black) tail
JR ds285MG
JR 3500G
GY401
sport BEC
step down reg for tail servo
blue skids
shorter flybar with lighter paddles
carbon fiber blades main/tail/paddles
will be a nice build will keep u guys up to date with it and shoot some vids when its done.
hear is a pic of what cam in so far
ID:	72755   Click image for larger version
ID:	72756   Click image for larger version
ID:	72757   Click image for larger version
ID:	72758   Click image for larger version
ID:	72760   Click image for larger version
ID:	72761   Click image for larger version
ID:	72762   Click image for larger version
ID:	72763   Click image for larger version
B400 DS285/3400G/401/-8/40Aesc/sonicCNC/CNCframe
TwinRexx: 6xHS-65/2xGY240/jfg500/TH2
CH-47D/UH-1H Crewchief/ Mechanic
sokal is offline        Reply With Quote
Old 12-17-2008, 01:09 AM   #2
sokal
more pics
ID:	72765   Click image for larger version
ID:	72766   Click image for larger version
ID:	72767   Click image for larger version
ID:	72768   Click image for larger version
Old 12-17-2008, 01:13 AM   #3
RVFR
That's no fair, I wanta play too. some people get all the fun...
The best way to get around www.whirl.me
RVFR is offline        Reply With Quote
Old 12-17-2008, 04:53 AM   #4
JCB287
Hey Sokal,why the tail servo step down reg if you are installing the Sport BEC ?
Never mind I see that you are using 285's (Duh) I'll shut up now......
JCB287 is offline        Reply With Quote
Old 12-17-2008, 06:34 AM   #5
BennyTRD
Unlike the 3400G, the 3500 can't or shouldn't take 6V. Looks good Sokal. Head looks nice and beefy. Should be a nice machine.
BennyTRD is offline        Reply With Quote
Old 12-17-2008, 11:49 AM   #6
Bigugly
very nice build
Are the sonix head and tail a better design than the stock b400 parts, or are they pretty much the same, just in aluminum.
Bigugly is offline        Reply With Quote
Old 12-17-2008, 06:47 PM   #7
sokal
Originally Posted by Bigugly View Post
very nice build
yes a diffrent design
the mixers are in line with the flybar that way the fly bar cant bind against them like the 400 head
also the flybar is abut further separated from the blade grips wich give more cyclic deflection.
lot of othe design diffreances.
one draw back is the ball links even tho the 400 ball links are suposed to be one way. but will allow you to use half adj. the rex head links will only go in one way so full turn adj wich mean to do tracking you may have to adj more than the pitch links. that means blade balancing is very very important.
Old 12-17-2008, 07:12 PM   #8
helibro6
Default none
me likey........
helibro6 is offline        Reply With Quote
Old 12-17-2008, 07:29 PM   #9
Jupiter20060
Man, That looks like it is going to be one nice heli.I love the head man
B400,DX7 w/3400g T.servo w/JR7703D Gyro,HS65-MGs on Cyclic,Sport BEC - Venom Night Ranger 3D/Walkera#22/Eflite,2.4 spektrum/DD Neu 12-30-4000 Tail motor, Thunderbird 9 ESC/complete seperates
Jupiter20060 is offline        Reply With Quote
Old 12-17-2008, 09:29 PM   #10
sokal
Default stock vs cncheli main shaft
both are the same length/size. the bottom holes match. the top holes dont reason is for the cnc head. had to move the hole to allow the flybar clearance in the rex style heads. both shafts will work in stock and cnc frame. and stock and cnc heads. you will have to mod the stock shaft my grinding some shaft off the top to allow the clearance for the cnc head. the cnc shaft is a solid shaft un like the hallow stock.
will keep updated as i go and answer as much as i can. i will take my time and give as good as an review/comparasons to help you choose your upgrade direction. i am anctous to fly but as usual im a dedicated b400 helper.
stock on the left (yes its bent) cncheli shaft on the right
ID:	72870   Click image for larger version
Old 12-18-2008, 12:08 AM   #11
sokal
Default more on the build
well got the tail, esc, motor and canopy in
tail is very nice.
shaft is steel alum removable geat 10t.grips have 0 play.sliger is bearinged on the no rotating portion.control arm is single point like stock. uses nylon bushings for slider portion and bearing for the arm. pitch change links are composit. and pinned in to the slider.the case is a single peace. stock shaft is not compatable. stock tail blades will need to be shimed (to slim for grips)
esc is quite big.
scorpion commander 45A esc v2
it comes in a nice pacaging. stickers, metal case. an IR programer and the IR remote.
looks like a very fine quality. and tons of features.
motor
the motor is a sonic 3500 kv motor gold and silver outrunner. mush stiffer to turn than stock. the motor is thinner and taller than stock. and will mount in stock motor mounts with no mods. came with a 13T pinion and compatable with stock main gear.
bullet conectors also are the same size as stock esc. not sure if stock esc is enought to run it effeciently.
.17mm shaft size.-------- Weight - 60 grams, Diameter - 25.8mm Length - 48mm Shaft length - 14.5mm Shaft Size: 3.17mm KV - 3500 current - 28A Max power - 320W
canopy
is a rex style fiber glass very stiff feels ruggid. has a opening under nose for vent prepainted glossy. will need to make own holes and gromits.
ID:	72908   Click image for larger version
ID:	72909   Click image for larger version
ID:	72910   Click image for larger version
ID:	72911   Click image for larger version
Old 12-18-2008, 10:17 AM   #12
Ragapiet
Thumbs up
great pics
the tail looks awesome aswell as the esc
Ragapiet is offline        Reply With Quote
Old 12-18-2008, 11:32 AM   #13
ted_wears_a_hat
Head and tail look like good quality work.
I'm particularly interested in the tail unit. Do you have a part number?
- EF Blade 400 - HS65mg/DS760/DS8910/440H/HW40/SAB325/3s/10t - Flight Log: 308 -
- MSH ProtŰs Carbon - HS-5245mg/DS760/DS650/SportBEC/MSH26-10/Jeti80/SAB425/6s/13t - Flight Log: 76 -
- BUILDING! - MSH Mini ProtŰs Carbon - HS65mg/Quark/DS8910/Scorpion/YGE/SAB325/3s/16t - Flight Log: 0 -
- Click here to view my RC Flight Log -
ted_wears_a_hat is offline        Reply With Quote
Old 12-18-2008, 05:04 PM   #14
ifheli
Sokal,
Looks good. It will interesting to hear the flight review. It should be a great flyer. You said the tail gear is a 10T. If it is the tail rotor rpm will be high. The stock one is 12T. You may have to change the front drive belt gear to help lower ratio back down. If you have to then the G5 gears can be used if you make a thinner shim. Outrage has a 10t,11t, and 12t that can be used.
Keith
Iím falling so Iím taking my time on my ride
ifheli is online now        Reply With Quote
Old 12-18-2008, 06:21 PM   #15
lowwing
scorpion esc v2 45a
cnc frame
JR ds285MG
JR 3500G
GY401
sport BEC
blue skids
On the upgrade should I have got the flybar from cncheli to fit the aluminum head or will the stock flybar fit and or work ok? Because it was not avalible when I had ordered.
lowwing is offline        Reply With Quote
Old 12-18-2008, 06:32 PM   #16
ifheli
The stock flybar should work. The only thing is the flats on flybar may not line up with set screws. The set screw don`t have to be set into flat spots.
Sokal should be able to compare it and see how they line up for you.
Keith
Old 12-18-2008, 06:44 PM   #17
lowwing
I guess I'll have to get it apart to see what your talking about the flat spots must be to keep it from spinning . Is this correct? Maybe I should go ahead and order the right part. It's cheap enough.
Old 12-18-2008, 06:58 PM   #18
ifheli
Where the setscrews in flybar cage touch flybar on stock head there will be two flat spots on flybar. They will keep the flybar from turning if for some reason the setscrews ever slightly backed out. Many helis don`t have flybars with the flat spots.
If you have the cnc head you can compare / measure the flybar cage to the stock one to see if the setscrews line up
Keith
Old 12-18-2008, 07:14 PM   #19
lowwing
I think I understand what your saying. But just so that when I go to put this back together, I ordered the flybar and the aluminum landing gear so I don't run into problems. I hate it when that happens. I thank you for your input and advice and happy holidays.
Old 12-18-2008, 07:16 PM   #20
ifheli
No problem..happy holidays to you also
Keith
