Old 12-17-2008, 01:06 AM   #1
babymoneek
Default Protos on 4s
Ive been searching and searching to see anyone with their protos set up with a 4s lipo. I cant seem to find any info on this. I'm trying to do something a little different than averyone else cause it seems like evertone that has the protos is pretty skilled, doing 3d and all. I just want to know if anyone has tried it yet. cause on the website it says i works with 4s thru 6s. I rather work my way from bottom to the top. what size pinion should i use. 20
babymoneek is offline        Reply With Quote
Old 12-17-2008, 04:20 AM   #2
Jafa
I'm running 4S 3700mah, Scorpion 1400kv, 15T pinion
It goes hard - but the battery gets to 54 degrees C
and it's only good for a 4 minute flight
which is ok considering I'm doing 3,000 on the head
6S is a more efficient setup and draws less current
I like 4S simply to share batteries with my Lepton and ePlane
The 4S 3700mah battery is lighter than the 6S 2500
and it also a bit cheaper to buy the 4S battery
Gryphon field rep
Jafa is offline        Reply With Quote
Old 12-17-2008, 10:39 AM   #3
babymoneek
Being cheaper is a major plus. But what pinion tooth should I use for the stock motor? I'm planning on getting one today. I didnt even think you could get 3000 headspeed with a 4s. That scorpion is a BEAST
MSH Protos 500, stock motor, 9650 Cyclic, 401 9257
Old 12-17-2008, 12:18 PM   #4
CatchmyCorsair
6s can be as tame as 4s. It's all in your setup. 6s usage evolved mainly out of the idea that we could use 2 3s lipos from our 450. Even if I was just hovering, I wouldn't go 4s. I don't want the heat.
You can run 6s and reduce your throttle curve, or more preferably change your gear ratio or motor Kv. I have a Kontronik Kora with a 690Kv that will be perfect for milder flight, so look for a Kv lower than 800 if you can to use 6s. Did you see Corrado's 12 min 2100 rpm demonstration of a "beginner's" flight? Do a search in this forum.
And the higher pinion tooth count, the faster your headspeed will be.
Steve
Trex 450 Pro
= MSH Prtos = E-Stratus
CatchmyCorsair is online now        Reply With Quote
Old 12-17-2008, 01:26 PM   #5
babymoneek
I guess i have to stop being cheap. The lipo charger that i have can only charge up to 5s. I could go with 2 3s lipos but i really dont want to go that route. Im trying to stick with a 4s or 5s. and since msh claims the protos flys good with the 4s i would like to try that. I never though about the heat though!
Old 12-17-2008, 01:30 PM   #6
psych-lick
4S will work fine with 18-20 tooth pinion. Just be careful with the current. 4S will draw much more amps thru the ESC and into the motor than a 5S or 6S will. I don't know how many amps the motor rated for but 4S on 20t will probably be pushing the limits.
Just realize that motor on this heli WILL consume upwards of 1200 watts at a high head speed and full collective.
1200watts / 14.5 volts = 82 amps!
fyi - the scorpion 3026-880 motor is only rated for 52 amps max continuous current.
-Jeff T.
psych-lick is offline        Reply With Quote
Old 12-17-2008, 01:41 PM   #7
CatchmyCorsair
If you can't go 6s, at least go 5s. (IMO)
Steve
Trex 450 Pro
Old 12-17-2008, 03:10 PM   #8
babymoneek
Thanks for all the help. I guess ill be ordering a 5s today!!
Old 12-17-2008, 04:06 PM   #9
Jafa
All good posts and information
Another point to remember is that the Lepton and Protos have the highest gearing of all the 500 helis - that's why I like to be on the smallest pinion to keep the gear ratio as low as possible
The 5S 3700 Outrage packs are a very good option
Gryphon field rep
Old 12-17-2008, 04:43 PM   #10
NolanManley
Better check the size of the 3700 even in 5S. Not much room under the canopy.
Stratus & Protos.
Magnum Fuel, KBDD intl Products
NolanManley is offline        Reply With Quote
Old 12-17-2008, 04:56 PM   #11
ayash
How do you change the gear ratio? Are there different gears for the Protos? The smallest pinion is 15 so can't go below that.
ayash is offline        Reply With Quote
Old 12-17-2008, 05:35 PM   #12
HighFreq
5S 3700 fit with no proble, actually the Protos has the largest battery space under the canopy in its class.
Corrado
www.msheli.com
HighFreq is offline        Reply With Quote
Old 12-17-2008, 05:43 PM   #13
babymoneek
Yeah I've seen a couple of people using the 5s 3700 lipo. Seems to fit pretty darn good! Im thinking of going with two zippy 5s 3600 20c until i get all into the insane 3d ill step up to more expensive batts.
Old 12-18-2008, 03:07 AM   #14
kgfly
Stock motor (800kv) 5S with 18t should give you a comfortable headspeed in the range 2200-2500 which won't stress the battery too hard.
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is offline        Reply With Quote
Old 04-06-2009, 09:14 PM   #15
spartan2381
Default Will this battery fit?
Looking to order ZIPPY Flightmax 4000mAh 6S1P 20Cand wanted ti know if it will fit. If not does anyone have dimensions and max weight of the largest battery this heli can support. Thanks.
Weight: 675g
Dimensions: 147x52x39mm
spartan2381 is offline        Reply With Quote
Old 04-07-2009, 01:43 AM   #16
Jafa
675 grams - nearly two times over weight
There may not be much collective pop with that on board
Gryphon field rep
Old 04-07-2009, 12:33 PM   #17
JustPlaneChris
Waaaaay too big (and heavy) for the Protos.
Chris Boultinghouse
Team MSH USA | Team Lynx Heli
JustPlaneChris is offline        Reply With Quote
