Originally Posted by srhammett
What are the dimensions for the holes?
I was going to say "are they the same as in the manual", but I get the impression the info in the manual is totally obsolete.
If you mean for the aileron servo wheel hole location, you use a one hole offset on the JR large wheel. That is, don't use the holes direct across from each other, but onone side move one hole away from the main shaft. And use the inner set of holes where there are two sets of holes.
Below is a CRUDE drawing. You want to use the hole indicated by the Red Arrow and either of the holes indicated by the Blue Arrows. NOT the one indicated by the Green Arrow, whic is the one directly across from the Red Arrow hole.
Terry
AMA#47402, IRCHA # 3395
