Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Electronics
Electronics Electronics Discussion
Old 12-21-2008, 11:58 AM   #1
oscar33
Smile Navigation lights of A 109 fuse
Hello,
Does any one have ideas the correct place to put the navigaton lights for A 109 fuse ?
oscar33 is offline        Reply With Quote
Old 12-21-2008, 01:17 PM   #2
Gus
Oscar33,
if you look at http://www.airliners.net/ , and search on Agusta A109, you can get it from the pictures.
Basically, the green navigation light is on the right Horizantal fin on the tail boom, the Red navigation light is on the left Horizantal fin, there is a red becon half way out on the bottom of the tail boom, another Red becon on the top behind the main rotor, and a White becon which appears to be on the top of the vertical tail fin.
Depending on the model, the Landing lights may be a single or double on the bottom of the nose, and/or a light on each of the wheel well extensions facing forward.
Hope that helps.
Gus...
Gus...
Synergy E5s, Goblin 380KSE, Gaui X3, Beam E4, T-Rex 250 Pro, MX-155, CF-226, CF-258, F1-5, F1-6, Chameleon, MX400s, AcroWhoop V2 (2), QR LB (DSM2) (2), SK SlowHawk 2, SK Park Hawk 4, Bionotic Bird, CF Wing, ThunderBird EDF Jet.
Gus is offline        Reply With Quote
Old 01-02-2009, 08:44 AM   #3
oscar33
Thankyou for your information.
Old 10-13-2015, 08:11 PM   #4
holytrex
Default A-109.... Lights.....
Hey guys I'm building an A-109 Coast Guard
And I'm also stuck on the light issue...
And I was wondering if I could put a strobe light on the bottom of the Fuselage...
Would that be. OK.. Or look stupid...
Cause I got my kit and light kit from
rcaerodyne.Com and its a 450 size..
So I have to put the red and green on the wheel pods.... Cause no way to put them on the stabs... LOL
And if it's not any trouble I'm using a trex 450 pro DFC and it only has one screw at front and back to hold the landing gear on..... So to mount the frame into the 109.. It calls for 2 screws front and back.... I need some advice on how to mount the frame into the fuse safely......
Thank you for your time and God Bless....
holytrex is offline        Reply With Quote
Old 10-14-2015, 08:13 AM   #5
cobieg
I have 2 450 scales that I used the frame landing skid mount using 1screw, no problem.
I didn't crash. I just ran out of airspeed, altitude, and idea's all at the same time.
cobieg is offline        Reply With Quote
Old 10-14-2015, 01:22 PM   #6
holytrex
Hey cool thanks bud.
I think I'm just going to run some long 2.5mm from the bottom up through the wood slabs and bolt it to the frame....
Thanks for help. Bro
Old 10-14-2015, 08:41 PM   #7
cobieg
Yeah, the ones I did, the frame sits on the bottom of the fuse.
Old 10-14-2015, 08:49 PM   #8
holytrex
Ya.... I wish mine was like that... But I have to use the wood to raise the frame high enough to get the head to clear and the tail boom to go down the Fuselage.... It's pain in the butt... Lol.... But I'm gonna make it work.
Cause if I didn't use the wood the head would not get high enough.. So it gets raised about an inch or so...
