some build questions
1. can i put my reciver on the bottom tray and my spartan on the reciver tray? 2. what is the best place to mount my esc and where to run the wires? 3. should i do the chinese weight mod? 4. what trottle and pitch curves should i run? im a newbie with no heli experince exept for the sim witch i am doing very well with i will be running a trex 500 gf with 5245's spartan 9257 dx7 ar7000 thanks for helping you can pm me if you want idnc
Jeremy Strickland SAB Goblin USA Team Pilot Questions? Send me a PM! |
#2 | |
2. on the bottom side of your lipo tray. 3. its not a must, but its a good mod. 4. for me: TC 0-75-100 (normal mode) and 100-90-100 (Idle1 and idle2) PC 0-50-100 (i use the same for all modes) but you may also use PC 35-50-100 (for normal). |
sorry i forgot to mention 5 point
thanks tho =)
That is 5 points just leave points 2 & 4 at INH and it will auto select the middle of 1 & 3 as point 2 and the middle of 3 & 5 as point 4 Example: 100 INH 50 INH 100 = 100-75-50-75-100 now if you ever change point 3 it will auto change 2 & 4 for you so.... 100 INH 80 INH 100 will auto change to equal 100-90-80-90-100 just by changing point 3 |
#6 | |
2. again, I agree with lavi, under the battery tray. 3. I'd say you don't need it with the stock tail. With the metal tail, yes. 4. When i first flew my 500, I was coming over from a little Honeybee FP. I found the 12 tooth pinion on 6 cells, with a normal throttle curve of 0, 55, 85, 93, 100 gave me a nice easy hover. For my normal pitch curve, I used something link 42, 46, 50, 75, 100. The way I arrived at it was to have about -3 degrees of neg. pitch at the bottom. A few other settings for a nice stable bird, for me at least, was 6 degrees of cyclic, 10.5 degrees of collective, and a little exponetial is a good idea on aileron and elevator, at least to start out with. Once you get around to doing flips and rolls, you'll want to increase your cyclic and collective. Hope this helps. Al
T-Rex 500 GF, S9650 MGs, Futaba CGY 750 FBL, DFC Head, DS8910A+ tail, Scorpion 1600 Compass Knight 3D, VBar, BLS253x3, S9254 tail, OS 50 Hyper, Multigov, Perfect Reg. T-Rex 700N, OS91HZ, BLS253x3, Multigov, BLS251+Quark, SG X2 |
#7 |
NORM == 0,85,85,85,85 == -4°,0°,12°
ST1 == 90,90,90 == -6°,0°,12° ST2 == 100,100,100 == -12°,0°,12° Use foam tape to mount the ESC right under the battery tray. Be sure no part of it can touch the sides of the frame. Some foam tape on the frame sides where the ESC could *possibly* touch would be a good idea. Assemble the heli and then take the left side of the frame off. Mount the servos and run/dress all the wires. It makes it a lot easier to have a clean bird that way.
She felt like someone of an ambiguous age that even neilg would approve of... |
#8 |
thanks
#9 | |
i used thro with 100 100 100,but it was a huge challenge for the battery.The battery can not suffer the amp,so in order to protect your battery,100 90 100 or 100 85 100is ok. I am chinese. |
