Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 01-03-2009, 03:25 AM   #1
JOMAZQ
Default just found a nice li'l gadget at the radio shack
Hey guys, just found a 12v dc adapter to banana jacks.
Just thought someone might like a ready made adapter from radio shack for ten bucks or so. My triton 2 works great with it
BLADE4003D.HS65MG.HS65MG.HS65MG.LT2100.LT3100G.222 1-8.ESC45A.NEED.NEW.BATTERIES.
BLADEMSR.HYPERION130MAH.DX6I
JOMAZQ is offline        Reply With Quote
Old 01-03-2009, 08:39 AM   #2
Heli Jim
12V is good but what amp rating?
Heli Jim
Blade 120 SR, Blade mCP X, DX6i
"If you're not flyin, you're not tryin' "
Heli Jim is offline        Reply With Quote
Old 01-04-2009, 01:33 AM   #3
JOMAZQ
It says it's rated for a 10Amp draw. Might be able to get more
Old 01-04-2009, 12:57 PM   #4
smoothb10
I just use an old PC power supply
US Army 1995-2007 Iraq 1st tour 2003-2004 2nd tour 2005-2006
Kiowa Warrior Crewchief 15s20
Reinlisted Army 30 Dec 2008
Signal Company Team Chief
smoothb10 is offline        Reply With Quote
Old 01-04-2009, 10:53 PM   #5
JOMAZQ
At home I use a converted pc power supply as well. I thought this would simplify field charging.
Old 01-05-2009, 05:33 PM   #6
JOMAZQ
http://www.radioshack.com/product/in...ductId=2102439
here's the link
Old 01-13-2009, 10:07 PM   #7
kelley
Thanks for the post, I can now charge in the field other then using friends batteries. My car battery is under the rear seat and not easy to access. I do though have 12V outlets in the back.
kelley is offline        Reply With Quote
Old 01-14-2009, 07:46 AM   #8
RPM 1.5
Had theses or a couple of years they are the BEST ONES to have others seem to break but theses last a long time,also you can unscrew the ends an they can use clips with them also
Ray
GOBBLE GOBBLE GOBBLE !!!!!!!!!!!!!!
RPM 1.5 is offline        Reply With Quote
Old 01-14-2009, 07:55 AM   #9
tfoutch
I have one of these. Your vehicle may not output enough throught the cigarette outlet to run your charger - mine will not.
Worth a try for $10 though.
tfoutch is offline        Reply With Quote
Old 01-20-2009, 07:38 AM   #10
Propaganda
I find a jump start unit works very well.
Propaganda is offline        Reply With Quote
