Old 01-07-2009, 04:00 PM   #1
Bradley Jones
Default I thought it was dumb till I tried it!! this is a dumb thread though haha!
The neck strap for your TX. I didn't see the need for it but I decided to try one out and it really does make holding the TX comfortable. Really the only advantage other than taking the weight off your wrists is it so much easier to trim and hit any of the switches cause you don't have to support the whole TX when taking your hands off to trim and make adjustments or changes. Don't knock the strap till you try it!!!!!!
Blade 400 3x DS285MG, DS290G Tail, G2703D Gyro, Trex 500 skids, motor-none, ESC-none, estimated finish date-unsure
Trex 250 aka the crash test dummy
Bradley Jones is offline        Reply With Quote
Old 01-07-2009, 04:10 PM   #2
Blade~400~er
i always fly with a neckstrap....also the adapter really helps to balance the whole thing out....makes it feel like its barely there.....
| TREX-500 SUPERCOMBO|
| BLADE-400 | MD500D Fuselage w/ Lights |
| TREX-450-SE/V2 |Align 3GX|Fusuno MD500E Fuselage|5 blade|
Blade~400~er is offline        Reply With Quote
Old 01-07-2009, 04:10 PM   #3
Penguin
I did the same thing, now I always use one!
B400 - 122/10 | T250 - 142/5 | T450 - 123/6 | T450 Pro - 67/2 | T600N - 52/0 | O550 86/0 | T700EC - 116/2 | T500 - 314/2 | L500 3D - 169/1 | L600 SE - 43/0
Penguin is offline        Reply With Quote
Old 01-07-2009, 04:11 PM   #4
Penguin
Where did you get that adapter?
Old 01-07-2009, 04:12 PM   #5
Bradley Jones
I think readyheli sells em and chcheli has an adapter like it also.
Old 01-07-2009, 04:18 PM   #6
Penguin
Thanks. I had the most expensive crash yet over the weekend. I set my heli and transmitter down on the driveway because my SUV was locked and I had to run in and get the keys, got sided tracked a few times, cames out and backed right over my DX6i. I ordered and just received a replacement DX7 and where the neckstrap lug is, its not balanced at all. Looks like that adapter would be perfect.
Old 01-07-2009, 04:24 PM   #7
Bradley Jones
I was wondering why you wanted one cause the dx6i is balanced perfect using the stock stud.
Old 01-07-2009, 05:45 PM   #8
M.Huerta
you can make one like i did, i will post a digram of it.
Forza 450
M.Huerta is offline        Reply With Quote
Old 01-07-2009, 05:57 PM   #9
Bradley Jones
yeah its easy to make, just get a strap,h clip, and a keychain hook thingy, all of which can be bought at a sewing shop for 3 bucks tops. I decided to spend the 10 bucks cause I'm lazy Plus the spectrum one (and a few others) has a tapered strap so its wider in the neck area and slimmer down low which is more comfortable.
Old 01-07-2009, 05:59 PM   #10
M.Huerta
no i made a balancer.
Forza 450
Old 01-07-2009, 06:03 PM   #11
Bradley Jones
okay that makes more sense haha. I was waiting for you to post a picture of a neck tie with a hook on it
Old 01-07-2009, 06:22 PM   #12
M.Huerta
Nah but my nexkstrap is also custom . I made the balanced with some steel tubing a screw a nut and a large servo horn it works pretty darn good with my dx7
Forza 450
Old 01-07-2009, 06:32 PM   #13
Bradley Jones
now that I think of it, didn't you post a picture of it before?
Old 01-07-2009, 08:21 PM   #14
M.Huerta
nope. i will try to though, ah crap i cant i do not have my radio it is with a friend of mine that is helping me setup my logo 10 and my gaui 200.
Forza 450
