Old 01-13-2009, 03:31 AM   #1
OICU812
Default Align please make some lighter paddles for the 250
I got some neg expo in this little guy to help out but the roll rate even all cyclics maxed out is a tad slow. I am hoping Align will make some lighter paddles or play with the flybar ratio to speed it up abit. Hope I am not alone in my wish?
Mikado Heli
Scorpion Motors
Western Robotics RC,
Youth Generation Electronics
OICU812 is offline        Reply With Quote
Old 01-13-2009, 06:09 AM   #2
Roadrune
I'm on thin ice here, but wouldn't cutting them down a bit help? Or will it be worse since the missing steering response?
A longer flybar should help aswell.
T-rex 600N, 8717, V-bar, 8900, YS50.
MSH Protos, 3517, Mini V-Bar, 3500.
JR DSX9
Rune
Roadrune is offline        Reply With Quote
Old 01-13-2009, 09:23 AM   #3
Coolice
Hey,
You could lighten them out yourself by drilling some holes in the rear of the paddles, behind the threaded hole in which the flybar screws into. Then cover them in some thin heat shrink so they work in the air.
Of course try to make sure you leave enough material at the trailing edge to maintain the paddles integrity, also by doing so this way you will keep the centre of gravity forward, otherwise they will become very unstable in flight.
This was a trick used many years ago by fliers of the original Concept30 helicopter's who wanted faster cyclics.
Personally, with a set of 205D Carbon Blades on (some add a 16T pinion as well but I have not as yet) I would have said you would not need for a faster cyclic response :-)
Ian Contessa
Team Robbe SchluterUK / Midland Helicopters / Align
Coolice is offline        Reply With Quote
Old 01-13-2009, 09:29 AM   #4
kimmy
I've noticed that too. I tried increasing the cyclic swash mix but it's still slow even to the point of binding. how about gaui paddles?
kimmy is offline        Reply With Quote
Old 01-13-2009, 12:49 PM   #5
fireup
Team Taco CEO
I'm planning on making myself one out of balsa, will see how it works.
Kevin
Don't Taco My Pack, Bro! ,
Why crash when you can POUND it!
fireup is offline        Reply With Quote
Old 01-13-2009, 05:39 PM   #6
Finless
Team Taco VP
Hmmm wonder if the Gaui 200 paddles would fit!
Bob
Old 01-13-2009, 07:30 PM   #7
OICU812
Bob
Hmmm yea nice thought, I dunno I wish I still had some around to try though!!!
Mikado Heli
Scorpion Motors
Old 01-13-2009, 09:10 PM   #8
rickyg
I don't know about lighter paddles, but after putting on the carbon fiber blades (they are so shiny) the stock paddles don't look so hot.
Ricky
rickyg is offline        Reply With Quote
Old 01-13-2009, 09:30 PM   #9
cbrian4
Im sure microheli or Align will step up and make some carbon paddles in the very near future. For some reason microheli made a carbon fiber anti-rotation bracket. Who the heck would buy that? its 15 bucks too!
cbrian4 is offline        Reply With Quote
Old 01-13-2009, 09:59 PM   #10
snjbird
Do you guys really think it needs them? I have my cyclic turned up to 80% and the thing flips and rolls like crazy?
snjbird is offline        Reply With Quote
Old 01-13-2009, 10:03 PM   #11
Popsicle
The Gaui 200 paddles won't fit. The Align flybar is too thick to fit into the paddles.
I don't know what I'm doing differently from you all, but my cyclic agility is excellent with the stock setup. I do know that my cyclic was horribly slow until I put on CF blades and the 16t pinion..
Popsicle is offline        Reply With Quote
Old 01-13-2009, 10:28 PM   #12
Hoverup
Ricky
Get the black magic marker out and cover them with color. They look less ugly and disappear when rotating.
Hoverup is offline        Reply With Quote
Old 01-13-2009, 11:50 PM   #13
cbrian4
I did that to my esc, i hated the way that the yellow looked against the black carbon fiber lol!
Old 01-14-2009, 02:39 AM   #14
OICU812
Yes sir, well.... I do anyways. I got the 16 tooth pinion as well, and the cf 205D blades, and all cyclics maxed right out to bind in extremes on bench. We shall see, maybe they will make some,,,,, just maybe....
Mikado Heli
Scorpion Motors
Old 01-14-2009, 02:57 AM   #15
fireup
Team Taco CEO
Going with leading edge control also helps. specially with quicker stick to cyclic response time.
Kevin
Old 01-14-2009, 03:21 AM   #16
OICU812
Any ill effects visible in flight in doing so Kevin???
Mikado Heli
Scorpion Motors
Old 01-14-2009, 03:39 AM   #17
fireup
Team Taco CEO
Nope, I think it flys better. (just make sure you rev. your swash pitch)
Kevin
Old 01-14-2009, 07:44 AM   #18
snjbird
I added these to make them look better
Old 01-14-2009, 10:20 AM   #19
LoveMyTrex
but those stickers will slow them down even more.
I am not overjoyed with the cyclic response stock (15t+plastic blades) but 16t and 205d blades looks like the cyclic is great.
I am putting the 205 carbons (LHS was out of the D's) on and a spartan gyro. it should fly pretty well like that.
600N 8917HV's spartan 760/8900G OS 55HZ/hatori SAB-55 AR7100r switchglow
700N 8717HV's spartan 760/8900G OS 91HZ/hatori SB-20 AR7100r switchglow, 690 slick V2 V's
90SG 8717HVs spartan 760/8900G OS 91HZ/hatori SB-20 AR7100r switchglow, 710 slick V2 V's
LoveMyTrex is offline        Reply With Quote
Old 01-14-2009, 11:12 AM   #20
cb3d
Hey Kevin, it may just be the angle of the picture but it looks like there is some extreme stress on your canopy mounting bolts.
Blade 130 X, Trex 700E DFC, SAB Goblin 700, Gaui x5 FES.
DX 18QQ
cb3d is offline        Reply With Quote
