Old 01-15-2009, 06:40 PM   #1
copperkiid
Default Need MSH ball resizing tool!
I'm got my Protos used second hand with no ball resizing tool. What is the MSH part number for the tool and where can I find one? I know the JR tool is to big. Thanks
copperkiid is offline        Reply With Quote
Old 01-15-2009, 07:02 PM   #2
rcmarty
I haven't seen them anywhere as of yet.
-Might consider asking the guy you bought it from real nice if has it around or not.
-Put up a post looknig for one from someone who has more than 1 kit
- try asking corrado
- I did see a post one day about a cheap kit , no blades,motor,etc for about 2-225ish
good luck
Martin
Logo XXtreme 800 8917 / 256HV VBC
rcmarty is offline        Reply With Quote
Old 01-19-2009, 07:42 AM   #3
jgoodwin
In the mean time you could try a trick I did with my 450. Take an extra ball preferably with the long thread and rough it up with sandpaper, even better file a couple of grooves in it. If you can find something to both it through to give you more of a grip. I used a 450 frame stand-off. Now it may not be a sharp as the original Protos tool so you may either have to work longer at it, or cheat and chuck it in a drill. If you use a drill be careful not to over size them!
-Jay
T-Rex 600 - 12s - 4025-630kv - 14T - 6965HB - 770-3D - S9254
Protos - 6s - MSH - 14T pinion - DS3405MG - HG-5000 - HSG-5083
T-Rex 450 - 3s - 430L - 13T pinion - 65MG - LT2100T - JR3500G
www.helichaos.com under construction?
http://www.youtube.com/profile?user=grizzlyadams72
jgoodwin is offline        Reply With Quote
Old 01-19-2009, 09:36 AM   #4
Bradley Jones
not sure what size the stock protos links are but heres a JR tool
http://www.readyheli.com/Ball_Link_S.../jrp960219.htm
Blade 400 3x DS285MG, DS290G Tail, G2703D Gyro, Trex 500 skids, motor-none, ESC-none, estimated finish date-unsure
Trex 250 aka the crash test dummy
Bradley Jones is offline        Reply With Quote
Old 01-19-2009, 11:25 AM   #5
copperkiid
The JR tool is to big.
